Camper shell with bed liner?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bs 02 Taco, Jan 15, 2009.
  1. Jan 15, 2009 at 8:37 AM
    Bs 02 Taco
    Bs 02 Taco [OP] Well-Known Member
    Amelia, Ohio
    02 Tacoma 4x4 regular cab 5 speed
    Swiss cap Deckplate Stupid door chime Synthetics AFE pro dry JVC Ipod compatible head unit Vanilla air freshener :) 25%tint
    Hey fellas, and ladies, I have a swiss top on my 6 ft. bed.
    The bed has a liner that goes over the rails.
    I am getting water leaking in.
    Is this because of the liner, or maybe not fitted correctly?
    If you have any pics of your mounted, and the gap between the back of your cab and the front of the cap I would greatly appreciate it.
  2. Jan 15, 2009 at 8:45 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    I have installed caps for years and although more difficult, sealing the cap the liner is generally not a problem.
  3. Jan 15, 2009 at 9:23 AM
    Bs 02 Taco
    Amelia, Ohio
    Thanks for responding.
    Do you have any advice?
    Maybe a pic or two...
  4. Jan 15, 2009 at 9:33 AM
    Rtrn2taco
    Philadelphia
    I usually use two or three layers of the foam tape stuck to underside of the cap rails to compensate for any hills and valleys caused by the possible bedliner warpage. The front rail (bulkhead) of the bedliners usually is about a 1/2'' lower in the middle then the side. Sorry no pics
  5. Jan 15, 2009 at 9:37 AM
    Rtrn2taco
    Philadelphia
    I just noticed in the pics that your cap has an aluminum base rail. The aluminum base rails creates seams between the fiberglass shell and the base rail (screwed together from the outside behind the screw cover). Now a days most caps are made with fiberglass rails eliminating the possibility of water getting in thru this seam. Try sealing this seam with silicone and see if it helps.
  6. Jan 15, 2009 at 9:40 AM
    Bs 02 Taco
    Amelia, Ohio
    Ok, thanks.
    Where does it have to line up on the front of the bed?
    I dont want it to squeak, so I think I may have mounted it too far back from the cap
  7. Jan 15, 2009 at 10:19 AM
    Rtrn2taco
    Philadelphia
    its not so much where in the front it should line up it is in the back. The rear door just be slightly away form your tailgate in the down and locked position (caution the cap could wear the paint on the tailgate). Getting the back set correctly will dictate how close to the cab the cap is. I hope that makes sense.
  8. Jul 12, 2009 at 1:25 PM
    crestlinerguy
    crestlinerguy New Member
    09 Tacoma
    Hoping someone can help with a question about fiberglass caps.
    I have a 2009 double cab with the plastic bedliner over the rail.
    Would like to add a glass cap. Dealers are telling me I have to have a new cap in order to fit. Of course new Leers start at $1200. I have found several used in great shape for 3 to$400. Do they sell clamps and gasket material to allow the used models to work without leak?
    Appreciate any thoughts.
    Cap confused:confused:
  9. Aug 21, 2009 at 8:53 AM
    Fla-Fish
    Fla-Fish Member
    2006 Tacoma 2.7 4cyl 5spd 4X4 Access Cab
    I think I found my answer just need to find the right clamps.
    2006 access cab 2.7ltr 4X4 and added a used commercial cap
    with ladder racks so I can carry my kayak on top and all my gear inside.
    Fit is decent just an inch or so short on the width in front.
    So if I am reading this right I need to find clamps that slide in the track
    and clamps down the cap. (aluminum rails with a tool box drivers side) I guess I cut the drivers side toolbox ?? to fit the clamps after I find the right ones.
    Any suggestions ??
    Angle bracket might work and just screw it to the bottom of the toolbox.
    Thanks in advance for the help.
