Camping and Backpacking GEAR thread
Discussion in 'Outdoors' started by T4RFTMFW, Aug 16, 2014.
  1. Aug 30, 2018 at 7:41 AM
    #8281
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Oh, that reminds me. After I hit the SOS button one of the messages from them asked if I wanted them to call my emergency contacts. I said no, and thank you. I sent a message to my wife, her cell, to say what happened.
    Two way is the way to go.
    With it paired to my phone, I can text anyone in my contact list. But, it comes from a 'Strange' number. You need to let them know that it is from you.
    Ken in NC
    DoorDing, socalktk and DVexile like this.
  2. Aug 30, 2018 at 12:56 PM
    #8282
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    Yep. I did this with a borrowed InReach 2 Summers ago. Guy broke his ankle above 13,000'. They borrowed a Spot from a passing hiker, and then he left with it. Heli showed up and couldn't see them in the rocks (didn't know where they should be looking). I was contacted by other hikers, borrowed an InReach and went up to them. Once contact was established I was able to give them precise instructions on needed gear, injury and location for the next morning. Long, cold night but a very successful ending and the kid that loaned me the InReach didn't have his girlfriend panicking at home.
    DoorDing and DVexile[QUOTED] like this.
  3. Aug 30, 2018 at 1:36 PM
    #8283
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    I put a quick messages on my Garmin inReach explorer reads:
    I'm OK, SOS msg is for someone else. No IN/OUT msg until SOS is canceled.
    Will send msg when I am able.
    I had a similar msg on my Spot, never used it.
    Since it took up to 10 minutes before Spot would send and w/o any indication that the msg was sent I would have to guess if it had been sent. Nice with the inReach that I can send the above msg right away then trigger the SOS.
    DoorDing and DVexile like this.
  4. Aug 30, 2018 at 2:21 PM
    #8284
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    The previous examples ^^^^^^ are the main reason why I was leaning towards the mini over the spot or ResQLink PLB.
  5. Aug 30, 2018 at 4:17 PM
    #8285
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    If going with a single device I'd recommend an inReach something or other. The PLB is the most reliable in an actual emergency as far as being certain a message will get through with poor sky view, rain, heavy forest cover, etc. but in the 99% of the cases that the inReach will also get through the fact it allows two way communication will make coordinating a rescue much easier and more reliable. And as already mentioned you can use an inReach as a deadman switch to handle cases in which you are unconscious or trapped with no sky view (e.g. fall down mine shaft, a real thing where I often visit) while a PLB offers no protection in those situations.
    DoorDing likes this.
  6. Aug 30, 2018 at 4:31 PM
    #8286
    OnePuttBlunder
    AZ
    The mini is a Garmin inreach. Not super worried about poor sky view or heavy forest cover (AZ has its advantages). I liked it because it has both the SOS function and the messaging part so it saves me from needing two devices. My wife will appreciate the messaging so I can send the pre formatted messages to check in with her when I am out on the AZ Trail. Then for me if something bad happened and I can not self rescue I have the SOS as a backup.
    https://buy.garmin.com/en-US/US/p/592606
  7. Aug 30, 2018 at 4:34 PM
    #8287
    DVexile
    Ken
    Yeah, I know. I own one :). Point was any of the inReach products would do the job (including the Mini). There is little if any reason to buy a Spot these days. The PLB is different from both with a bit more reliability than anything inReach in an actual emergency but a PLB is a big compromise in that is the only thing it does.
  8. Aug 30, 2018 at 4:38 PM
    #8288
    OnePuttBlunder
    AZ
    Ahhh gotcha I took for the inreach something or other as you were not sure which one it is, not a reco to pick up any of the inreach choices.
  9. Aug 30, 2018 at 8:43 PM
    #8289
    Borrego Taco
    Borrego Taco Well-Known Member
    2017 DCSB TRD OR 4x4
    I have an old Delorme InReach SE for over four years.
    It has always sent messages or tracking points out. Never has it dropped one.
    My main “emergency” use has been to coordinate getting someone out of a situation close to an emergency, but not one yet.
    My other main use is letting people at home know everything is ok, but I am delayed by hours and not to call SAR.
    I also use tracking as a last known location in case anything goes really wrong.
    I still file a plan at home and don’t count on the InReach. I always tell people it could break it, malfunction, or be lost. No news is good news until the drop dead time/date.
    DVexile and DoorDing like this.
  10. Sep 3, 2018 at 6:20 AM
    #8290
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Is that a choice?
    I can text my wife while SOS is active.
  11. Sep 3, 2018 at 1:42 PM
    #8291
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    I did, and it was not a problem. So much time between messages.
  12. Sep 3, 2018 at 6:42 PM
    #8292
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    The more important aspect, regardless of the tool being employed (smoke signals, whistle, cell phone, inReach, sat phone) is having the conversation with the person(s) you would be communicating with, and understand each other's expectations. Example
    You may decide you will share your Trip Plan with an individual, but only contact them when you need to, or when you are not back by a certain time frame, and you provided clear instructions on what you expect them to do and who to call passing on the information from your trip plan
    Another example is you may check in by text at each stage of your trip, updating your intentions along the way. "At the trailhead", "half way up", "will check in in 4 hours", "need a ride at 10 am" etc. When they don't hear from you, after your pre-determined intervals, then that triggers some action on their part that you've discussed.
    As for what information of what to communicate- location, time, current circumstance, weather, what actions you are going to do, and what you are asking for or expecting, finally what resources you have at hand.
  13. Sep 3, 2018 at 6:47 PM
    #8293
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    & InReach works better than Spot, in terms of getting a signal out from.my experience.
    DVexile, OnePuttBlunder and DoorDing like this.
  14. Sep 4, 2018 at 9:31 AM
    #8294
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    Had a successful overnight at Consultation Lake and summited Whitney the next day.
    My gf received all my messages and updates from my Inreach Explorer + fine all weekend.
    DoorDing, OnePuttBlunder and DVexile like this.
  15. Sep 4, 2018 at 10:18 AM
    #8295
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  16. Sep 4, 2018 at 10:25 AM
    #8296
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  17. Sep 4, 2018 at 11:32 AM
    #8297
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  18. Sep 4, 2018 at 11:55 AM
    #8298
    OnePuttBlunder
    AZ
    On the subject of rescue. I'll use myself as a good example from Saturday. Plan was to summit Picacho Peak in the lower AZ desert a 1.2 mile ascent with 1900 feet of elevation gain. Weather forecast was initially mid to high 70's as a low with high temps around 99 We usually do not reach high temps in AZ until 4-5pm. Actual weather at 7:15am 92 degrees 30% humidity, and climbing. Up on the trail 95 ambient + heat reflection off the cliffs. Normally I would consider this a fun hike/climb cause I love sketchy scrambles. I made up about 1000 feet in .7 of a mile and felt the effects of the heat. Instead of being an idiot and continuing on I decided to turn back, I felt some of the symptoms of heat related illness, skin turning cool and clammy. No vomit but feeling nauseous. While I probably could have found some shade rested and continued. The sections above us are the more technical part involving near vertical climbs and traverses along a shear cliff face with pre attached cables. I decided it was not worth the risk to my friends and SAR should I have continued and succumbed to the heat up above the cables. I headed back down the hill, cooled off with my chilly towel and waited for the others to finish. A couple others ended up turning back, and the rest of the group looked miserable when they finished. If myself or someone else pushed too hard and needed to be rescued it was pretty clear it would have ended up endangering a lot more people.
    Ccwahoo, JJ TACO, Sdtrueblue and 4 others like this.
  19. Sep 4, 2018 at 1:15 PM
    #8299
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Good on you Matt, for being self aware, and able to adapt your plans to the conditions.
    With Hyper or hypo thermia, it was good that you made decisions before the extreme temperatures affected your ability to think clearly. If you wait too long to make those decisions, one of the physiological effects, is your brain function; ability to process information, and make rational decisions on that information digresses very rapidly, and you won't notice.
    I look for the signs that I simply call 'mumbles, stumbles, and fumbles' - Mumbles changes in speech patterns - either someone that is normally chatty is not, or vice-versa, they get quieter, or their topics shift focus rapidly. Often their short term memory is also impacted.
    Stumbles is fairly obvious, faltering in their stride, or simple obstacles becoming difficult.
    Fumbles - simple motor skill tasks such as opening a water bottle, or sandwich bag, or forgetting that they put their hat down and its not on their head.
    Any or all signs of change to take notice, that things are deteriorating for that individual, even if you do not feel its effects.
    Talk to someone you suspect is struggling, ask them simple questions and observe their reaction will quite quickly confirm if intervention is needed.
  20. Sep 4, 2018 at 1:29 PM
    #8300
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Often need for SAR calls, are not from a single, catastrophic event, but a combination of little slip ups, and decisions, that culminate in 'oops, now i'm in trouble." For the audience here, understand that SAR does not 'judge' you on your actions to determine if you are worthy of a SAR callout. (We've done dumb things ourselves!) We do base a level of response on factors of your circumstance such as known injury or medical condition, are you by yourself or in a group, terrain, weather, age. The more honest you are in communicating your circumstance when you request help, regardless if YOU think it maybe embarrassing, the better co-ordinated response you will get.
    Trust me - we laugh about your circumstance, AFTER you are out of your predicament, then relate how we may have done similar stuff, or be blown away by your amazing luck in some cases.
    Gunshot-6A likes this.
