Camping and Backpacking GEAR thread
Discussion in 'Outdoors' started by T4RFTMFW, Aug 16, 2014.
  1. Oct 14, 2019 at 9:55 AM
    #9261
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    You betcha!
  2. Oct 15, 2019 at 6:35 AM
    #9262
    Bubbarut
    Bubbarut Well-Known Member
    2011 Super White Access Cab V6 4x4 6SPD Manual
    You can use some alum foil and fold it around the top of the griddle and down past the opening to help block the wind. You can see in the pic how I did the sides. I do this a lot and you would be surprised how much it helps.
  3. Oct 15, 2019 at 2:26 PM
    #9263
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Just bought a trangia spirit burner. My first alcohol fuel burner. What do you guys use for fuel? Anybody got any recommendations?
    I’ve been reading up on types. Just not sure what to get.
  4. Oct 15, 2019 at 3:16 PM
    #9264
    Flatliner
    Flatliner Well-Known Member
    Robert
    2008 Tacoma Double Cab TRD Sport
    Fox and Icon Suspension upgrade
    We use heat in our alcohol stoves but I'm not familiar with that one
    Red18Taco707[QUOTED] likes this.
  5. Oct 15, 2019 at 3:38 PM
    #9265
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    denatured alcohol in qts or gal at wally or other bx stores wherever cheap. get a Triangia fuel bottle either in 1 liter or .5 liter size. They are the only ones that I've used that don't leak!
    It looks like water but has different surface tension properties (if spilled it just runs all over the place, therefore demanding greater care with transfers).
    Red18Taco707 and skier like this.
  6. Oct 16, 2019 at 3:07 AM
    #9266
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Briefly.
    The very best is pure grain alcohol, 90+%. But that is expensive.
    Next is ethanol. Denatured has toxins in it to make it undrinkable. So, there are some of those toxins that go into the air when burning. I buy gallons of the stuff at Lowe's.
    There are newer bioethanol products available. There are quite a few alcohol burning 'fireplaces' and they provide fuel and fuel cells. Regal Flame sells that fuel. I bought 12 qts on Amazon and got free shipping. Compare prices.
    Methanol is last. Isopropyl also. Use these only when you have to.
    Yellow Heet is s good fuel. NOT the Red Heet.
    Visit https://classiccampstoves.com/
    Lots of great information there. A lot of good helpful people.
  7. Oct 16, 2019 at 4:27 AM
    #9267
    G.T.
    G.T.
    CONUS
    When buying the Magma nesting stuff consider getting the add on accessories, when added to the mix the whole pile gets slightly taller but the added colander is worth it with its built in folding handle as hanging storage while prepping.
    If your cook setup has dual burners and you like to use them both then get an additional handle so you don’t have to fiddle with the back and forth swapping game.
    Did just add this Uniflame toaster to the mix. Will be using it this weekend as my boy loves toast with his eggs at camp.
    A4DE2278-A991-4B55-9559-7EF204B2F504.jpg 5685209F-79F4-40BD-87FF-0208DBAA66EA.jpg
    Phoosa likes this.
  8. Oct 16, 2019 at 7:38 AM
    #9268
    INBONESTRYKER
    WY
    @2Toyotas Denatured alcohol is ethanol with methanol added to make it poisonous to humans and other critters. Toxins emitted are CO & CO2. Because the methanol makes it undrinkable it's not taxed like ethanol. On the other hand grain alcohol can be used in cooking and to give a little zip to your hot chocolate.:)
    2Toyotas and Red18Taco707 like this.
  9. Oct 16, 2019 at 7:47 AM
    #9269
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    I use yellow Heet with my Trangia.
  10. Oct 16, 2019 at 7:53 AM
    #9270
    INBONESTRYKER
    WY
    Heet in the yellow container is methanol and comes at a higher price than denatured.
    2Toyotas likes this.
  11. Oct 16, 2019 at 7:54 AM
    #9271
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    What makes you guys prefer alcohol stoves over canister stoves?
  12. Oct 16, 2019 at 7:55 AM
    #9272
    T4RFTMFW
    There are differences between the two. I prefer Heet at the end of the day.
    Lot of info online going through comparisons.
  13. Oct 16, 2019 at 7:55 AM
    #9273
    T4RFTMFW
    I don’t prefer it, but the nice thing with alky is the silence.
  14. Oct 16, 2019 at 10:13 AM
    #9274
    Flatliner
    Robert
    I use both and go with yellow heat purely because I am regularly at places to buy it. The canister is much less hassle and I use it for actual cooking as a rule, but I find both a diy alcohol stove (my coffee set up) and a small twig stove rewarding at a primal level. The fact that I can use a silent alcohol stove on the side of a quiet lake as the sunrise happens to make coffee is bordering on a religious experience. Stoves are like mods and potato chips...
  15. Oct 16, 2019 at 11:01 AM
    #9275
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    Thanks for the info gents! Appreciate it :cheers:
  16. Oct 16, 2019 at 11:05 AM
    #9276
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Just pop in here periodically but for any of you looking for a cast iron grill/griddle- AmazonBasics now makes one. You can get them new for only 30ish dollars or do what I did and pick up a "refurbished" one for $27. Hell of a deal and we put it to the test out by the lake last weekend and it killed pancakes, sausage, burgers, and steaks no problem at all. Good way to cook like a King without paying like one
  17. Oct 16, 2019 at 12:20 PM
    #9277
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    I did, they both fit.
    I also got the pads that go between the pots, and is also a trivet or pot holder.
    And benzine and other bad shit.
    I haven't had a drink in a long time.
    G.T.[QUOTED] likes this.
  18. Oct 16, 2019 at 12:23 PM
    #9278
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    if only I can get JUST the lid for one of those coal dutch ovens...
  19. Oct 17, 2019 at 3:26 PM
    #9279
    levie125
    levie125 Well-Known Member
    2019 DCLB TRD
    I considered myself a minimalist....then I had kids. I live in Colorado and you can never bet on being able to use a fire to cook off of so I made an investment in a Camp Chef Expedition 3x. Best money I have ever spent. There are 3 burners total, 2 close together under the griddle and 1 off to the side. The legs come off of it for easy transport but it is quite large. You can pull it out of your truck and have it set up in less than 5 minutes.
  20. Oct 17, 2019 at 4:38 PM
    #9280
    T4RFTMFW
    ready6delta and levie125[QUOTED] like this.
