Camping and Backpacking GEAR thread
Discussion in 'Outdoors' started by T4RFTMFW, Aug 16, 2014.
  1. Dec 17, 2019 at 12:21 PM
    #9421
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Thanks for the recommendations...I’ll look into both of them
  2. Dec 17, 2019 at 6:24 PM
    #9422
    Flatliner
    Flatliner Well-Known Member
    Robert
    2008 Tacoma Double Cab TRD Sport
    Fox and Icon Suspension upgrade
    Grams are ounces, ounces are pounds, that Olight looks heavy.
  3. Dec 17, 2019 at 6:50 PM
    #9423
    Planespotting
    Planespotting Well-Known Member
    Miles
    Michigan
    2019 SR5 V6 DCSB, '74 FJ40, 05 Ducati Multistrada S
    Decals!
    ...and uncomfortable. But those lumens!
  4. Dec 18, 2019 at 9:15 AM
    #9424
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I’ll more than likely just end up with a Black Diamond again
  5. Dec 18, 2019 at 10:29 AM
    #9425
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Nitecore NU25 headlamp with the big heavy headband removed and modded with some DCF tape, and some medium stretch cord and a lineloc so it fits all size heads and also fits over beanies, ball caps, hoods, etc. I even hang it around my neck like a "chest light" and that has been handy. USB rechargeable. It tilts vertically. Has 3 white settings and 2 red settings, not including strobe settings. I get over 5 days on the low setting (that's continuous use in testing). Low is enough to see around camp and in the tent. I get 8 hours continuous on the medium setting which is plenty for night hiking. Weight of this setup is only 1.16oz. Otherwise I use a 1 AAA small titanium flashilight
    ETAV8R, 4WDTrout[QUOTED] and G.T. like this.
  6. Dec 18, 2019 at 10:32 AM
    #9426
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Why carry 2 pads and have the extra bulk and weight?
  7. Dec 18, 2019 at 11:03 AM
    #9427
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Keeps me warmer/ground cold off me more and I sleep more comfortably from the extra padding.
    If you have any recommendations, I’m open to hearing them
    Seabass[QUOTED] likes this.
  8. Dec 18, 2019 at 1:29 PM
    #9428
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Neoair Xlite has over 2" of loft and has the internal baffling to give it a higher R value. If you really sleep cold, get the Xtherm which has an insane R value over 5. One pad, all the comfort and warmth you need. Heavier than the Prolite, but for good reasons. And only 1 pad to deal with that still deflates and packs down pretty small.
    Your body heat is only being reflected back by the Prolite, so the Sol foam pad is keeping only minimal cold from hitting the Prolite. Let your body heat warm up a better pad like the Xlite or Xtherm for much better single layer insulation. And they are comfortable. I'm a big guy and I never slept better than I have on my Xlite and Xtherm. Plenty of loft for heavy side sleepers.
    Permagrin and 4WDTrout[QUOTED] like this.
  9. Dec 18, 2019 at 1:55 PM
    #9429
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    I always use two pads in the snow, but usually not otherwise.
    Seabass, 4WDTrout and G.T. like this.
  10. Dec 18, 2019 at 3:43 PM
    #9430
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Thank you for the recommendation, I’ll check it out. :thumbsup:
  11. Dec 18, 2019 at 3:48 PM
    #9431
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    This is the way I place my sleeping pads when I’m backpacking.
  12. Dec 19, 2019 at 8:06 AM
    #9432
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    yeah I don't sleep on rough surfaces and always have the tent floor as a barrier after clearing the ground. If you're cowboy camping more than tent camping, maybe consider a thinner roll of closed cell foam if that's all you need it for.
  13. Dec 19, 2019 at 8:06 AM
    #9433
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    absolutely
  14. Dec 19, 2019 at 3:38 PM
    #9434
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    So, I was just using the picture as reference to show the pad placement is all. I’m usually in a tent.
  15. Dec 19, 2019 at 5:08 PM
    #9435
    Michaelo
    Michaelo Well-Known Member
    Michael
    PNW
    2014 Regular Cab 4x4 5 Speed
    I too have that pack. I saw one at an REI garage sale but then passed on it, seriously regretting passing on it, and then bought another one at their next sale.
    I have only hiked with it once and it did a great job loaded in the 20lb range. I have loaded it at home with a little over 35 and hit the treadmill and that was terrible though so I'm not sure yet...
  16. Dec 19, 2019 at 5:28 PM
    #9436
    G.T.
    G.T.
    CONUS
    Talking about insulated pads, I expect an insulated Klymit static V to arrive soon. I’ve used their pillows and seat cushions before so I figured I’d try the pad and worst case just give it to my son to use with his scout gear.
    ETAV8R likes this.
  17. Dec 19, 2019 at 6:04 PM
    #9437
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    I've got four static Vs. Three are insulated. If you have the type with a Male inflate valve I've got a YouTube video on how to inflate them on my build thread...
    https://www.tacomaworld.com/threads...nd-some-wanderings.84336/page-4#post-14963746
    G.T.[QUOTED] likes this.
  18. Dec 23, 2019 at 7:00 AM
    #9438
    TacoDia
    TacoDia Well-Known Member
    St. Louis
    11 DCSB SR5 V6 OME Kit H-Dakars
    I'm looking for recommendations on a new table for a base camp setup. Going to be used for cooking, prep and cleaning. Currently using one of those plastic folding Rubbermaid style which isn't bad but I want something more sturdy along the lines of https://www.frontrunneroutfitters.c...ess-steel-prep-table-with-foldaway-basin.html but hopefully more affordable. One with a basin would be great but doesn't have to have one. Any suggestions? Thanks
    tundraconvert likes this.
  19. Dec 23, 2019 at 8:57 AM
    #9439
    skier
    Keith
    SW Colorado
    These are hard to beat and often available at 40% off..
    https://www.coleman.com/outdoor-compact-table/2000020279.html
  20. Dec 24, 2019 at 4:04 AM
    #9440
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    I got this.
    https://www.alpsbrands.com/alpsmountaineering/products/furniture/regular-dining-table
    Ken
