Camping and Vehicle Battery
Discussion in 'Outdoors' started by KVTaco, Sep 21, 2019.
  1. Sep 21, 2019 at 3:26 AM
    KVTaco
    KVTaco [OP] Well-Known Member
    Morning
    How does a battery hold up when camping and using it for a few small appliances? The common wisdom seems to be that the 3rd gen OEM battery is poor to begin with. Do folks bring a second battery or have other means of having electricity?
    Thanks in advance.
  2. Sep 21, 2019 at 7:30 AM
    huachuca
    huachuca Well-Known Member
    Al
    Tarboro, NC
    2012 4WD DC w/TRD offroad
    We often camp in remote areas so I'm a bit paranoid about killing my starting battery and any use other than its intended purpose is a no no for me.
    What sort of 'small appliances'? 12 or 110 volt? Amp draw? How long do you intend to run said appliances? Budget?
    Without more info, I'd suggest a booster pack / jump starter with built in DC output plugs (cigarette lighter and USB) and inputs so it can be recharged from the Tacoma. Expect to spend $150-200 - the cheap stuff is junk. NOCO https://no.co/products/power/jumpstarters has some quality products with USB outputs. If you need 110V, get an inverter to go with the booster pack (400W will run around $50). Goal Zero https://www.goalzero.com/shop/porta...0VVBOXZlIZbs3TS7M6Y2lwDWz_D24AIMaAi5wEALw_wcB may also have something that would work for you.
  3. Sep 21, 2019 at 11:38 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I agree with this 100%. I've used the 100 amp battery in my solar power system to jump the dead truck battery, something it is not designed to do.
    Get a solar power system. They come in many sizes and configurations. To have power in the middle of nowhere is a game changer.
  4. Oct 3, 2019 at 8:49 PM
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    I ran my battery down once while camped in a pretty remote area. Hadn't seen anyone around in over a day. Someone finally drove past around dark and I flagged them down for a boost. Was definitely a lot more careful after that, and I picked up a portable booster when I got home. I've had to use that a couple times as well when my battery has gone bad.
    For charging things like phones and small usb devices you can pick up portable usb chargers cheap on Amazon.
  5. Oct 8, 2019 at 9:40 AM
    smartbomb
    smartbomb rcvr/xmtr
    usually northwest of you
    2006 4-door prerunner long bed
    3" suspension lift, hard canopy, light bar in hood, ditch lights, aircraft cargo bars, powdercoated steel spares, desert tires, bed cargo bars (for rifle cases), misc interior doo-dads
    I just use one of those portable jump boxes for usb charging and a few outlets. it's not too heavy, no wiring, and I don't have to keep it in the truck when I don't need it
  6. Oct 8, 2019 at 10:05 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Your starting battery is not a deep cycle battery and is not designed to be drawn down and recharged like one. Charging your phone or tablet is one thing, running appliances, especially if you're using an inverter, is another. I would not use the inverter without the truck running. Buy a spare battery, jump box, power pack or whatever for your toys, having your main battery die off the beaten path sucks. If you insist on using your truck's starter battery then I'd keep one of the small emergency starter packs on hand such as the Antigravity packs. Expensive, but far less than having to call for a jump in the middle of the woods.
