Camping gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by carlsv650, Jan 15, 2009.
  1. Jan 15, 2009 at 5:59 PM
    carlsv650
    carlsv650 [OP] Well-Known Member
    Colfax, NC
    05 PreRunner TRD
    Extra "D" Rings, ARE MX Truck cap carpet lined with entry door. mods to bicycle mounts
    I just had an ARE Mx series cap installed. I also had the carpet bed installed. We intend to use our new addition to take our cats with us on weekend trips. I hope our cats can adjust? Please, all you animal owners out there let me know what you've done to help your pets adjust. Also I would like to see how tacoma owners have outfitted the inside of their truck caps?
  2. Jan 15, 2009 at 6:21 PM
    carlsv650
    Colfax, NC
    05 PreRunner TRD
    Thanks. I did a small test this afternoon. I put them in the back with me for 10 minutes. So far they seem ok. What about litterbox and food? I will put Velcro under the litterbox for traveling.
  3. May 11, 2014 at 7:24 PM
    mike2013
    mike2013 New Member
    Lake Cormorant, MS
    2013 Double Cab SR5
    Looking at the combo you have (2013 DCSB with ARE MX), but am concerned that it will not fit in my garage. What is the max height,accessories you added and how do you like this combination? Good luck with the cats.
  4. May 12, 2014 at 4:59 AM
    KB Voodoo
    KB Voodoo Well-Known Member Vendor
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Cats aren't like dogs. They aren't going to like it back there very much.
  5. May 12, 2014 at 5:04 AM
    mh.meier
    mh.meier PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper(, color matched -Heretic Studios 20" single row light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -Front custom satoshi gille, color matched -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Dirt King stock length lowers (soon to be installed) -Sway-A-Way 2.0 rear ext travel shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Somthing that helps is to put a blanket or something in the back that you use that has your scent on it. That will help them calm down a little bit but of course evry animal is different.
  6. May 12, 2014 at 5:35 AM
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    While driving they'll be in the cab i'm assuming? That would be the route I'd go, should make them feel much more comfortable. I don't know if your shell has a pass-through window to match your sliding back glass or not but that might be nice too.
    Here's my parents and their chihuahua with his Doggles on.
  7. May 12, 2014 at 5:48 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2017 Black GMC Sierra SLE 5.3L
    Cats? Going camping? Ok then...
  8. May 12, 2014 at 8:12 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Just leave the cats home. They wont even notice you are gone.
  9. May 12, 2014 at 8:19 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    ^^^This
    Get one of those big hopper feeders and a couple water bowls. They'll be all set.
