Camry won't start after fueling
Discussion in 'General Automotive' started by ramonortiz55, Oct 8, 2015.
  1. Oct 8, 2015 at 6:15 PM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Just as the title states.
    I have a 2003 Toyota Camry that struggles to start every time I fuel up.
    I can't figure out what it is. I have replaced the filler neck and the gas cap.
    It happens every time I fill the gas tank:
    First time I turn the key after fueling, engine starts but car has rough idle, then shuts off.
    I try turning it on and engine turns but won't start. Need to try starting it two or three times for the car to start.
    I have no problems any other time. ONLY after a fill up.
    295,000 miles, 4 cylinder.
  2. Oct 8, 2015 at 6:20 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Tank fuel filter? fuel pump? Check pressure before/after fill-up.
    Toyko Joe and Dalandser like this.
  3. Oct 8, 2015 at 6:22 PM
    ramonortiz55
    Ramon
    Texas
    stock
    I've thought about that... but if it was the pump or filter, wouldn't it happen every time?
  4. Oct 8, 2015 at 6:37 PM
    tonyly
    tonyly Well-Known Member
    Tony
    Los Angeles
    01 Tacoma Prerunner Ext Cab
    Replace your purge valve, this is what is causing your car to not want to start after refueling.
  5. Oct 8, 2015 at 6:48 PM
    ramonortiz55
    Ramon
    Texas
    stock
    That's been replaced already
  6. Oct 8, 2015 at 7:23 PM
    tonyly
    Tony
    Los Angeles
    Is there a check engine light? If so, did you pull the codes? Are you sure you replaced the purge valve and not the fuel filter? The purge valve is what releases the fuel vapors to be burned by the engine. If the valve is stuck, it will be hard to start after you gas up. Avoid topping off at the gas station as this will damage the purge valve.
  7. Oct 12, 2015 at 3:29 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Yes, purge valve was replaced.
  8. Nov 16, 2016 at 2:35 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Even if I don't top it off, the problem still happens.
  9. Nov 16, 2016 at 3:02 PM
    Tacoma Mike
    Southern Maine
    Do you let the car sit for a length of time any other time? Or do you restart the vehicle within 5 min other times?
  10. Nov 16, 2016 at 3:04 PM
    ramonortiz55
    Ramon
    Texas
    stock
    The car is my daily driver. I restart it multiple times a day.
  11. Nov 16, 2016 at 3:05 PM
    Tacoma Mike
    Southern Maine
    Like I asked do you restart it within 5 min at other times during the day?
  12. Nov 16, 2016 at 3:06 PM
    ramonortiz55
    Ramon
    Texas
    stock
    It only has a rough start, as if it was flooded, after I fuel up. The only way around it is to fuel up with the vehicle running.
    I have replaced the gas cap twice, thinking the first was "defective".
    I replaced the fuel filler neck.
    I have replaced both purge valves.
    Still get the issue. I've had it for over a year, I'm just getting tired of it.
  13. Nov 16, 2016 at 3:07 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Yes. No issues at all.
  14. Nov 16, 2016 at 3:11 PM
    Tacoma Mike
    Southern Maine
    Ok do you have a fast idle when the vehicle is cold like 1200-1500 rpm?
  15. Nov 16, 2016 at 3:17 PM
    ramonortiz55
    Ramon
    Texas
    stock
    I really don't think so, out of all the vehicles I have, the 4runner is the only one that does that... We have had cold mornings lately, I can double check the Camry tomorrow morning
  16. Nov 16, 2016 at 3:29 PM
    Tacoma Mike
    Southern Maine
    Ok 2 things I want you to do.
    You need that fast idle when cold.
    If not then the next time you fuel up just touch the gas and hold it for 5 seconds while you crank it up. Like your manually getting it to about 1200 rpm. After 5 seconds let the gas pedal go slowly to idle.
    If it idles fine then first you need to clean the throttle body plate and housing especially along the edges of the blade. You don't need to remove the throttle body right now. Once done see if you get the fast idle when cold and see if it makes a difference during fuel up. If you still don't have a fast idle the the next poss. problem is your AIS or IAC motor depending on your way of saying it.
    That motor compensates for your start up hot and cold. I think once you get a cold idle up your other problem will go away.
  17. Nov 16, 2016 at 3:36 PM
    ramonortiz55
    Ramon
    Texas
    stock
    So my ideal cold start up range is 1200 - 1500 RPMS , correct?
  18. Nov 16, 2016 at 3:37 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Wait, so what does the cold idle starting have to do with the starting after fueling the camry after its already warmed up and what not?
    I definitely need to look into cleaning that throttle body as well. .. hmm..
  19. Nov 16, 2016 at 3:37 PM
    Tacoma Mike
    Southern Maine
    It varies from year and make but if it's cold out and a cold start rpm is the same as warm rpm or close to it then it's not right.
  20. Nov 16, 2016 at 3:38 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Got it.
