Camshaft Position Sensor Location on 1GRFE
Discussion in 'Technical Chat' started by bradforj, Dec 18, 2018.
  1. Dec 18, 2018 at 8:37 AM
    bradforj
    bradforj [OP] Well-Known Member
    TN
    07 4x4 v6 TRD Sport
    2012+ Front End Swap 2014 steering wheel swap w/audio and BT controls 2014 power window controls 2014 lower center dash and radio bezel 2014 a/c controls Auto-dimming mirror Heated side mirrors Turn signal side mirrors Backup camera DNX890HD head unit Kenwood speaker system Kobalt slim toolbox In-channel Ventvisors N-Fab running boards
    I am getting code P0345, bad camshaft position sensor, bank 2. I plan to replace the sensor, but I am wondering if anyone can help me find its location on the motor? I have found information leading me to believe it is on top of the motor on the driver side, also referred to as a VVT sensor. Is this correct?
    Also, is it part number 90919-05060?
    One final edit: the starting problem only presents itself if the truck sits for a full day or more without being started. It is not a battery issue, though. The battery is fully charged and is not being drained, yet my clock and radio lose all settings when I have the starting problem.
  2. Dec 20, 2018 at 8:25 AM
    bradforj
    TN
    07 4x4 v6 TRD Sport
    Anyone?
  3. Dec 20, 2018 at 8:50 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    It appears they're inside the valley between the heads under the intake manifold.
    bradforj[OP] likes this.
