Camshaft position sensor location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ty4X4, Feb 9, 2018.
  1. Oct 14, 2018 at 11:13 AM
    #61
    morelia
    morelia Well-Known Member
    conroeeee
    k&n intake. hid kit sound system
    Lmao. By then I'll be 3k deep in that bitch and are more likely to set it on fire .
  2. Oct 14, 2018 at 11:28 AM
    #62
    morelia
    conroeeee
    What did you diagnose and fix?
  3. Oct 14, 2018 at 1:32 PM
    #63
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Driver side intake cam gear was a tooth off. His links were off as well. Cranked and cranked the engine over to line them up, and they never would. Checked the TDC for cylinder 1, and made sure that side was lined up properly. Then realized where the problem was.
  4. Oct 14, 2018 at 1:42 PM
    #64
    morelia
    conroeeee
    So what was it
  5. Oct 14, 2018 at 1:45 PM
    #65
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    He covered it in the first sentence:
    Torspd likes this.
  6. Oct 14, 2018 at 1:47 PM
    #66
    morelia
    conroeeee
    Lmao. Long day . But wouldn't you get the code for that bank? As p0012 is specific to passengers side?
  7. Oct 14, 2018 at 3:01 PM
    #67
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am sure it did, as well as it ran really poorly. This was over 6 years ago though.
  8. Oct 14, 2018 at 4:27 PM
    #68
    morelia
    conroeeee
    Mine doesn't really run poor at all .has a slight vibration every 5 seconds or so . And feels slightly sluggish. But that's it.
  9. Oct 14, 2018 at 5:41 PM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds pretty poor to me. Is the cam position sensor bad?
  10. Oct 14, 2018 at 7:07 PM
    #70
    morelia
    conroeeee
    Naw .Ran worse when bad gaskets . New sendin
  11. Oct 14, 2018 at 7:08 PM
    #71
    morelia
    conroeeee
    Sensor
  12. Oct 15, 2018 at 6:04 AM
    #72
    craigs1
    Sounds like how mine ran with the stretched-out main timing chain, and bank 1 nearly 8 degrees retarded versus crank. Seemed to run fine, but it really smoothed out and regained power after the chain replacement. I'm really thinking either he timed bank 1 cam wrong, or the VVT actuator was damaged when the cam broke.
  13. Oct 15, 2018 at 6:15 AM
    #73
    morelia
    conroeeee
    Yeah he replaced the chain . Maybe . He says he's checked the timing three times. Idk man. Almost at the point I want to take it from him and pay someone else . Been a month and a half already .
    SR-71A likes this.
  14. Oct 15, 2018 at 6:17 AM
    #74
    craigs1
    Have him do what I posted.
    1.) Pull the passenger side valve cover, put the crank timing mark at zero, then snap a pic of the cam sprocket/VVT actuator showing the timing marks on it and the intake cam bearing saddle. Also snap a pic of the exhaust cam sprocket showing the timing mark on it and the exhaust cam bearing saddle.
    2.) Pull the 4-bolt timing chain tensioner cover and snap a pic of the tensioner showing the plunger.
  15. Mar 14, 2020 at 9:36 AM
    #75
    daytrader2
    daytrader2 Well-Known Member
    mw
    2" suspension lift/wheel spacers.
    Need an expert opinion here.
    Earlier this week I replaced the passenger side OCV valve, the old one was definitely bad, I tested it with 12V and no movement at all.
    I cleaned the filter too, it wasn't too bad.
    I thought I had it fixed but I didn't drive the truck much and Thursday/Friday it keeps throwing the P0012 code again. Reset it several times.
    Now there's always the off chance I got a bad part from AZO, which I hope it is but I have a couple questions before I proceed.
    1) Could running the truck for a long time with the bad OCV valve mess up the Camshaft Timing Gear Assembly. I wouldn't think it would, but I should probably ask.
    2) Just as in #1 above, could that cause looose or jumped teeth in the timing chain?
    3) That VVT sensor shown in post #18 of this thread.... obviously any part can go bad, but do these(?) and will it trigger that code? I'm reading this and I see no mention of it: http://tacomaface.epizy.com/FSM/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/0060013.pdf
    The fact that the original OCV valve was bad really has me leaning towards just a faulty replacement part. I'll pull both the filter and the valve out again, but any thoughts on the above questions?
  16. Mar 14, 2020 at 3:04 PM
    #76
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you tested the new OCV with voltage?
    daytrader2 likes this.
  17. Mar 14, 2020 at 3:12 PM
    #77
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    If you take the valve covers off you can check the timing on the cans. If off half a tooth, stretched or worn timing sprockets. Takes about 1.5 hrs disassemble and reassemble. Not hard.
  18. Mar 14, 2020 at 8:09 PM
    #78
    daytrader2
    mw
    I didn't have time to pull it out today, but that'll be the first thing I check.
    Well that's good to know, that its easy to do. Will it be obvious to actually see 1/2 tooth difference? And/or a stretched chain?
  19. Mar 15, 2020 at 4:44 AM
    #79
    specter208
    California
    Yeah, just take a straight edge onto the cam timing mark and try to line it up with mark on the bearing cap. Very simple.
    daytrader2[QUOTED] likes this.
  20. Mar 15, 2020 at 3:55 PM
    #80
    daytrader2
    mw
    Yeah I pulled the filter, it was clean, 12V tested the valve, it worked, checked the cam timing, as best as I can see, its ok too. Still throwing the stupid code. P0012
    So, I go back to what I asked about the sensor on bank 1, could it be the cause and is there a test? Next question, all thats left (I think) is the camshaft gear assembly. It looked fine... but I suppose that doesn't matter.
    One thing I did notice though, and I thought about it later when I put it all back together, was when I pulled the filter, I didn't get any oil dripping out. I wonder if there's a chance that whatever path the oil takes after that filter to the OCV valve could be clogged?
    This is driving me crazy now. Its war. The good news is the engine compartment is so darn clean now, I barely have to wash my hands when I'm done.
    SR-71A likes this.
