Camshaft position sensor OBD codes
Discussion in 'Technical Chat' started by koozer22, May 17, 2011.
  1. May 17, 2011 at 5:43 AM
    koozer22
    koozer22 [OP] Member
    Ooltewah, TN
    2006 PreRunner SR5 TRD Offroad
    Hey guys,
    OBD came back with two error codes: p0345 and p0348. Both are for the camshaft position sensor. The engine runs great and I don't notice any problems, but I can't pass emissions.
    Anybody ever run across this? Everything I can gather tells me that the sensors are probably not bad and I don't want to replace them unless I have to. Any other thoughts on what I could check?
  2. May 17, 2011 at 6:50 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check all the leads for the sensor. Look for grounds and shorts. Check the wire from the plug on the ECU to the sensor's plug. Do this with a multimeter.
    If you find no wiring issues, replace the sensor.
    Considering that the sensors control spark timing as well as fuel injection, once there is a hard fault, the engine won't run. It won't know when to fire.
  3. Jun 10, 2011 at 3:19 PM
    koozer22
    Ooltewah, TN
    Alright, I replaced both vvt (cam shaft sensors) and now I get p0018
    Now the engine is shaking badly when driven over 30 mph. Wire harness looks good. What else could it be?
  4. Jun 10, 2011 at 3:42 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
  5. Jun 10, 2011 at 3:42 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Possible that when you installed the sensor you did not seated right. Or its not connected correctly.
