Camshaft Position Sensor - P0018
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Andrew83, Dec 13, 2017.
  1. Dec 13, 2017 at 9:39 AM
    Andrew83
    Andrew83 [OP] Active Member
    Andrew
    Orange County, CA
    07 PreRunner DCSB
    I have a 2007 prerunner v6 and recently got a check engine light and the code that is coming up is P0018, I know that is for the Camshaft Position Sensor, however I am not noticing any difference to the way it runs prior to the code coming up. I have cleared it twice, but not sure if I need to replace the sensor or not.
  2. Dec 13, 2017 at 3:29 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    most likely the chain is stretched
  3. Dec 13, 2017 at 3:32 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    That would be one of the first times i have heard of that.
    More than likely its a VVTi unit on the front of the cam. Does it ever start up and act real strange during the first 10-20 seconds of running after sitting for awhile? Theres a lockout pin in the vvti that has been known to go bad or stick that makes it to where the cam doesnt get locked out before oil pressure is built up enough for the VVTi assembly to function properly.
  4. Dec 13, 2017 at 7:28 PM
    Blacktaco2042
    wisconsin
    i work at the toyota dealer and that is the common fix for them on the older ones
  5. Dec 13, 2017 at 7:31 PM
    Blacktaco2042
    wisconsin
    its a correlation code means that usually the timing is off. i would clear the light and see if it comes back. sometimes it will suck up some junk and it will not let the cam gear work right and it will throw that code too
  6. Dec 14, 2017 at 11:27 AM
    Andrew83
    Andrew
    Orange County, CA
    07 PreRunner DCSB
    Doesn't to act strange during the first 10-20 seconds. Is the lockout pin an easy thing to fix?
    The common fix is the lockout pin for the VVTi? Could it be the sensor and I just need to replace it?
    I have cleared it twice and it came back both times.
  7. Dec 14, 2017 at 11:29 AM
    nd4spdbh
    SoCal
    the vvti assembly needs to be replaced which requires removal of the entire cam chain assembly, which blows.
    Maybe try replacing just the CPS first (though i think its kid of a bitch to get to as its at the back of the motor if im not mistaken)
  8. Dec 14, 2017 at 11:31 AM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    Have you done the obvious? Look for rodent damage. They love those wires. Do that before getting too crazy.
    Andrew83[OP] likes this.
  9. Dec 14, 2017 at 11:34 AM
    marinetaco
    Bobby
    2005 Tacoma TRD
    The VVT-I AND cam position sensors are on the front. Look at the valley near where time timing cover and heads meet the block.
    Andrew83[OP] and Torspd like this.
  10. Dec 14, 2017 at 12:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How re
    This
  11. Jan 4, 2018 at 7:35 PM
    DIRT TACO 16
    DIRT TACO 16 Well-Known Member
    Greg
    2016 TRD OFF ROAD 4X4
    AIR CONDITIONING DRAIN EXTENSION
    Marinetaco, funny you should say that , this morning started my truck and the trac light and check engine light was on, we to dealer and a rat had eating one of the wires on the cam sensor. to repair the wires they have to take the intake off. Est 600.
