Camshaft position sensor resistance question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Jul 29, 2022.
  1. Jul 29, 2022 at 6:15 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I am getting a reading of 1.1 (200k). Supposed to be 835-1400. Could this be due to a possible wiring issue? Or if that was the case would I be getting no reading at all? It’s just that if I’m going to remove it & this reading means it’s definitely shot, I might as well wait until I have the new one. On the other hand, if there’s hope, I’ll get in there & look at it 1st.
  2. Jul 29, 2022 at 10:04 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your on the 200,000 ohm scale on your meter?
    The sensor is unplugged from the harness ?
    Your reading is 1.1 or 1100 ohms tells me your in the range.
    If you had infinite resistance the sensor would be open depends on your meter some show the infinity sign others say over load.this tells you the sensor has failed.
    It might be possible to get 0 resistance with some sort of strange short in the sensor
  3. Jul 29, 2022 at 11:00 AM
    Kristi with a K
    Western MA
    I was just researching. So yeah,
    Thank you. I was slowly coming to realize I was incorrect in my interpretation of the results. I wish I had the electrical basics down. I mean I am ok when the FSM states a range along with the setting. For instance testing the TBS.
    Other times when I'm on a mission & get help with it, I'm thinkin' "I got this", & I do, until it's a bit down the road & another issue comes up. I do retain a little each time, so that's somethin'.
    Ok. Wait. Noggin is pondering it again. I was getting screwed up over conversion. I watched a vid in which the guy set it at 20k. Then another in which it was set at 200k. They each got 2.1 & then both converted to 2,100. This made me tilt. I see now that in each scenario, it was just a matter of moving the decimal over three.
  4. Jul 29, 2022 at 11:02 AM
    Kristi with a K
    Western MA
    Yes. Unplugged.
