Camshaft Positioning Sensor Wiring P0348 Code displayed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Penfolda, Oct 29, 2022.
  1. Oct 29, 2022 at 1:28 PM
    Penfolda
    Penfolda [OP] New Member
    Alex
    2005 TRD Sport 4x4
    Hey all, I had some rats chew through my sensor wires and I thought it was a super simple fix until I pulled back the loom and found one yellow wire and 2 blue wires that were identical. Does anyone happen to have a wire diagram or know what wires should have voltage when the key is turned over? The code P0348 is displayed for the sensor.
    Thanks in advance
  2. Oct 29, 2022 at 3:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Pretty sure the one that will have 5v on it will go to Pin#3 on the connector. (VC wire)
    That wire is the 5v reference wire I believe.
    @Dm93 will know for sure. So we’ll wait and let him give us the OK:thumbsup:
    I suppose a sure fire way to know, would be check continuity between pin #3 of the other cam sensor. (The other one only has 1 blue wire) But that’s more work.
    10775B7A-A732-4556-A09F-305A6090A420.jpg C9B9A887-CF3A-4DFA-8127-CA806CF06E24.jpg
    Dm93 likes this.
  3. Oct 29, 2022 at 3:52 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm not sure if it's a pull up or pull down sensor, I'll check when I get time.
    TnShooter[QUOTED] likes this.
  4. Oct 29, 2022 at 4:16 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok @TnShooter is correct one of the blue wires will have 5v on it with the key on, the other will not.
    The one with 5v (VC) will go to pin 3, the other one (VVL-) will go to pin 2 and the yellow wire (VVL+) will go to pin 1.
    Just a note the Yellow wire will also have 5v on it as it is a pull down circuit.
    TnShooter likes this.
  5. Oct 29, 2022 at 4:21 PM
    TnShooter
    Deogee
    STOCK
    Thanks.
    I was pretty sure it would have 5v.
    I think we had a discussion on that VC wire at one time.
    Dm93[QUOTED] likes this.
  6. Oct 29, 2022 at 4:24 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea the VC wire on Toyota's technically called Voltage Constant is the 5v supply for all the 5v sensors on the truck, it should always have 5v with the key on.
  7. Oct 29, 2022 at 7:06 PM
    Penfolda
    Alex
    2005 TRD Sport 4x4
    Thank you @Dm93 and @TnShooter that should be no problem. I appreciate it.
