Camshaft sheared the key help please
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bluedogcards, Oct 8, 2013.
  1. Oct 9, 2013 at 10:09 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Well, neither does her son and his friends. I hope she's taking to a reputable shop to have it looked at.
    Sounds to me like she needs a new PS pump body (including pulley) and belt. Its a relatively easy job, but the PS body is a bit pricey. They usually are sold without the reservoir, so that the old reservoir can be transferred.
    Hard to believe the PS pulley came off, if thats what happened. Those things are on there real tight.
    I looked at Rockauto.com, and it looks like the pumps are sold without the pulley or pulley nut either. Appears to have a spline, so there may not be a key.
    Her best bet may be to get a used one from a wrecker, and have a shop willing to install it. 4-cyl pumps are different from 6-cyl pumps. On the other hand, if the pulley came off cleanly, maybe all she needs is the pulley, pulley bolt and belt. Without photos of the engine bay, we are only just guessing at the real problem.
    Good luck
  2. Oct 9, 2013 at 11:29 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    That's what I was thinking, Rick. There is no key on PS pump pulley, it's splined. So, the only other key would be the crankshaft pulley. If it was the camshaft pulley key, it definitely would'nt run or have anything to do with the P/S not working either way.
  3. Oct 9, 2013 at 4:29 PM
    Bluedogcards
    Bluedogcards [OP] Member
    Eric
    El Reno Ok
    2001 Tacoma
    they are saying it it the harmonic balancer it is a simple fix or tear the engine apart
  4. Oct 9, 2013 at 4:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    If the key way on the crank is messed up the crankshaft needs to be replaced. That means pulling the engine and doing a full tear down. Might be cheaper to find a used engine if you don't do the labor.
  5. Oct 9, 2013 at 4:44 PM
    Robnik
    Rob
    Greenacres, Florida
    Like Steven said it depends on how bad the crankshaft is chewed up. The key is meant shear off if there's a problem. A new pulley won't be too bad. But a new crankshaft + labor is a lot of $$$$, Good Luck, Eric.
  6. Oct 9, 2013 at 5:13 PM
    Bluedogcards
    Eric
    El Reno Ok
    2001 Tacoma
    well if going to cost to much truck will be for sale as is
    thank all for all the comments
  7. Oct 9, 2013 at 5:14 PM
    Robnik
    Rob
    Greenacres, Florida
  8. Oct 10, 2013 at 8:12 AM
    Bluedogcards
    Eric
    El Reno Ok
    2001 Tacoma
    Robnik. great pic i see how this could be a problem, what would make that bolt back out , maybe today will get the true cost form the mach.
  9. Oct 10, 2013 at 9:38 AM
    Robnik
    Rob
    Greenacres, Florida
    If someone replaced the timing belt & did'nt torque it down to 217 ft-lbs, which is quite high. My torque wrench only goes up to 150 ft-lbs, so you really have to jam it on there or maybe they forgot to tighten it at all. :eek:
    Here's a picture of what someone had to do to remove the bolt on a Honda:
  10. Oct 11, 2013 at 7:38 AM
    Bluedogcards
    Eric
    El Reno Ok
    2001 Tacoma
    is there any other reason for it to come off, the only thing i have had done to it was a trans rebuild really not thinking there should be no reason for them to be on the front of the engine but never know
  11. Oct 11, 2013 at 8:50 AM
    Robnik
    Rob
    Greenacres, Florida
    Are you the original owner, because if that timing belt has'nt been changed in 12 years, it should be. That bolt is really on there from the factory. I've seen some that won't even budge w/ an impact wrench.
  12. Oct 11, 2013 at 9:20 AM
    Bluedogcards
    Eric
    El Reno Ok
    2001 Tacoma
    got it used, Sis just tested me truck will be ready today less then 200.00 glad to hear that, she is happy just wan't to give a big thank to you all for all the help and comments she will be coming home next week ya
  13. Oct 11, 2013 at 10:15 AM
    Robnik
    Rob
    Greenacres, Florida
    Glad to hear it too, Eric :yay: Just make sure you get a good mechanic to give it a good once over when she get's back. A $5.00 problem can be exponentially escalated. P.M. me if it's anything else. :)
  14. Oct 11, 2013 at 8:27 PM
    Bluedogcards
    Eric
    El Reno Ok
    2001 Tacoma
    Well knowing my sister she did not give me all the info yes she got her truck back not fixed the crank is bad on it, looking at dropping another engine in it did some seaching they are not bad about 1600.00 to 2000.00 plus the cost to swap it out would do it myself but been 20 plus years since a did an engine swap, not to get her home and somehow get the truck home if can't find someone there to do the work.
