Can’t find a rattle that’s driving me crazy!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rjwz28, Oct 13, 2019.
  1. Oct 13, 2019 at 4:46 PM
    Rjwz28
    Rjwz28 [OP] Well-Known Member
    Rob
    Big Island of Hawai’i
    2019 TRD sport
    Mostly stock. Icon wheels, running boards, sounds, custom grill, front camera.
    I got a 2019 double cab and there is a rattle in my front driver side door that I can’t locate. Only when I go over bumps and bad roads. Seems to be in the front upper part of the door. I removed the door panel and taped all the wires to the door and put some foam behind the door handle but it’s still there. When I take the panel off and drive it with the door bare it goes away. Tried hitting and shaking the panel by itself with no luck. Any ideas?
    Thanks.
  2. Oct 13, 2019 at 4:49 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Check out the rods for the door lock.:confused:
  3. Oct 13, 2019 at 4:50 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    There isn’t any rods
    GreyBaldTaco and Skydvrr like this.
  4. Oct 13, 2019 at 4:52 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Rattle or squeak? Mine squeak from the weather striping to the door jam
  5. Oct 13, 2019 at 4:54 PM
    Rjwz28
    Rob
    2019 TRD sport
    Definitely a rattle.
  6. Oct 13, 2019 at 4:57 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Pop the panel off and make sure the window regulator is snug and check wiring connectors to make sure they aren't hitting metal
  7. Oct 13, 2019 at 5:02 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  8. Oct 13, 2019 at 5:02 PM
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Mine was rattling from tweeter area.
    I swapped them out for the Subaru tweeters and it stopped for a few weeks but returned.
    I will try to locate the source of the rattle one day... for now I just turn the radio up.
    Da Boogie Man and shutupmeg4x4 like this.
  9. Oct 13, 2019 at 5:11 PM
    SpanishTaco
    SpanishTaco Well-Known Member
    CT
    2015 Blue DCSB TRD Sport
    You might try slipping a thin piece of rubber between door cover and metal (could be plastic door panel moulding tapping the metal).
    Also, check your door moulding fasteners, if flat metal squeeze spring types try expanding and put a dab of plasti-dip on the areas of spring that contacts metal.
    If plastic try replacing with larger ones.
    Final thought, if all else fails, you can try to squirt some spray expanding insulation foam in there, go easy on stuff since it will expand a good bit. That will definitely stop anything moving and rattling ever again in that space.
  10. Oct 13, 2019 at 5:51 PM
    MN_Taco
    MN_Taco Member
    KD
    Minnesota
    2017 TRD Sport Access 4x4 MGM
    I had the same issue with my ‘17. The dealer finally fixed it and it was the bearings (or something similar) in the seatbelt mechanism. This was fixed a while back so I don’t remember exactly how they fixed it but I think they put some type of foam and it solved the issue.
    Good luck!
  11. Oct 13, 2019 at 5:55 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I'd let the dealer figure it out.
    I do remember someone having a problem and it was the A pillar. Could it be there and when you take the door panel off it's affecting that?
  12. Oct 13, 2019 at 5:57 PM
    Tape
    Tape Well-Known Member
    Tape
    2019 Super White OR
    I've heard these trucks rattle and buzz but mine 11k miles is absolutely quiet
  13. Oct 13, 2019 at 6:02 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    My rattle was the a passenger rear window rubber guide that came off. @Rjwz28 Does your window make the same rattle when you shut the door?
  14. Oct 13, 2019 at 6:16 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Maybe Boz was at the plant stringing nuts when your truck was being built.
  15. Oct 13, 2019 at 6:48 PM
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    sounds like its the door panel rattling against the dash. try closing the door with a towel between the dash and the door take it for a ride and see if it goes away.
  16. Oct 13, 2019 at 7:40 PM
    veedo
    veedo Well-Known Member
    Is it the small plastic panel behind the inside door handle? Push on it when it's buzzing. Felt tape will do the trick if that's the culprit.
  17. Nov 15, 2019 at 8:32 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Mine is rattling when loud base hits the door speaker, and I've pinpointed it to the window switch module. The rattle goes away when I press against it. Hopefully, the mechanics at the dealership have a fix for this... :fingerscrossed:
    Skydvrr likes this.
  18. Nov 16, 2019 at 12:23 PM
    Rjwz28
    Rob
    2019 TRD sport
    I had the dealership “fix” it by replacing some speaker thingy in the dash. It’s still there. Going back Thursday to try again.
    Thanks everyone for all your comments and suggestions.
    I’ll post the results when it is corrected. When and if it’s corrected.....
    Rob
  19. Nov 16, 2019 at 3:27 PM
    tacothyme
    tacothyme Well-Known Member
    Cory
    Seattle, WA
    18 DCLB OR
    265/70/17
  20. Nov 16, 2019 at 3:44 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    I think my window switch rattles too
