Can’t get the CV axle back in!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mac84, Mar 19, 2020.
  1. Mar 19, 2020 at 8:33 PM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Crowbar is the easiest way to remove the CV too
  2. Mar 20, 2020 at 6:02 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I used a couple long 1/2" drive extensions with a bit of duct tape and I was tapping it in close to where the wheel would be.
    I used a socket to drive it in. It was large enough to put the extension in the socket from the work side and have a nice flat surface up against the bushing
  3. Mar 20, 2020 at 6:21 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    I lubed the cv splines and had a friend wiggle it up and down while i tapped it in with a prybar and hammer
  4. Mar 20, 2020 at 8:39 AM
    mac84
    mac84 [OP] Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Ok, update: got back out there and gave myself a little more room to get the axle straighter, also put some grease on the clip and oriented correctly. Then i pushes from the outside instead of underneath and it slid in like butter.
    Finally got it buttoned up and test drive was ok. No leaks and no vibes.
    Marc70, tacofish, dk_crew and 3 others like this.
  5. Mar 20, 2020 at 9:05 AM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Also consider the new C-clips on the splines will be tighter. In all my years of pulling and replacing my CV axles, I have never used a new clip nor have I ever had an issue. (That's just me)
  6. Mar 20, 2020 at 9:16 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I prefer to not use tools when putting the CV in. I grab the end of the CV and ensure the splines are lined up. Then I will use a light pull (to not seperate joints inside) and a firm push. I will do this repeatedly with force on the push and they go right in after 2-3 tries.
    mac84[OP] likes this.
  7. Mar 20, 2020 at 5:06 PM
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    I agree with Andrew again... the crow bar is the easiest tool to use to get it out also. Just make sure to to put the straight end in the gap next to the differential and pry cv axle out towards the wheel or outside of the truck. If you pull the pry bar towards the wheel you are prying against the metal plate protecting the diff seal.... not good it will dent and potentially damage the seal. So again put the pry bar in the gap and pull the curved end of the pry bar towards the center of the truck levering the cv axle out towards it's own wheel and it will pop right out.
    MolonLabeTaco likes this.
