Can’t program key fob 2002 Tacoma prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yotafan84, May 4, 2021.
  1. May 4, 2021 at 2:07 PM
    Yotafan84
    Yotafan84 [OP] New Member
    Joshua
    Hello and thank you in advance. Just purchased a 2002 Tacoma prerunner. It does have power windows and locks. All info online I could find tells me my truck should be able to have a key fob programmed. It just will not go into program mode. Have tried it so many times. Idk if this is a sign for anything but when I use the key in the drivers door I have to turn it twice to unlock all doors. If I use the key in the passenger door I only need to turn it once to unlock all doors. Have unplugged what I believe is the correct plug for the receiver. Unhooked battery several times. Made sure I have done the process correct at least a dozen times. Nothing. Please help.
  2. May 4, 2021 at 2:46 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    What is your FCC number on the keyless entry module? Does it match the fob?
  3. May 4, 2021 at 3:12 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    X2 on FCC#
  4. May 4, 2021 at 4:05 PM
    Yotafan84
    Joshua
    Thanks guys for the quick responses. I don’t see anything on the box I’m looking at. Is it behind the glovebox? I took the 3 10mm bolts out of the plastic liner inside glovebox. I thought I was looking at the correct thing. Thanks again.
  5. May 4, 2021 at 4:19 PM
    tntacomaguy
    tntacomaguy Well-Known Member
  6. May 5, 2021 at 8:06 AM
    Yotafan84
    Joshua
    Thank you very much. Will check it out as soon as I get home from work. I appreciate it a lot guys.
  7. May 6, 2021 at 8:31 AM
    Yotafan84
    Joshua
    Just wanted to update. I did remove the door sill plate and the kick panel. I do not have the receiver behind the kick panel. So no wonder I couldn’t get it to go into program mode lol. I am now tossing up the notion of buying a universal one I found on Amazon that there is a good detailed install video on YouTube. Only about 30 bucks too. Just wanted to thank you that posted.
