Can’t remove wheels, what now
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EngineerMatty, Jun 5, 2023.
  1. Jun 5, 2023 at 2:17 PM
    EngineerMatty
    EngineerMatty [OP] Active Member
    2009 Silver Tacoma Access Cab 4x4 TRD
    I was able to remove 2 of my 4 wheels for a tire rotation but 2 of them will not budge.
    I have removed the lugs, dropped the jack in efforts to pop them, whaled on the tires with a sledgehammer on the inner and outer surface of the tire, sat on the ground and kicked at the tires left and right, even sprayed some pb blaster/kroil into the lug area days before this. The damn rims won’t budge.
    I have the FN Five Star rims which at the time I thought were great but now FN has a whole new meaning. I noticed the two rims I could get off had some burrs around the lug holes and they fit tight on the bolt pattern.
    Do I have to open up the lug holes a bit? But importantly how to get the other two off??
    Has anyone struggled like I have or had a similar problem with these rims?
  2. Jun 5, 2023 at 2:25 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Maybe they weren't correct fit for a toyota. Maybe meant for another vehicle? Isn't Chevy hub pattern close but not the same?
  3. Jun 5, 2023 at 2:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    Are the back ones the stuck ones?
  4. Jun 5, 2023 at 2:33 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    FN wheels are hub centric to our trucks I believe. Did you clean the hubs before installing the wheels?
    SR-71A likes this.
  5. Jun 5, 2023 at 2:33 PM
    TegoTaco
    Ontario, Canada
    Do you have wheel spacers?
  6. Jun 5, 2023 at 2:34 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Might have to get in there with a torch somehow and heat them up
  7. Jun 5, 2023 at 2:35 PM
    Rainier
    Rainier Well-Known Member
    OC, CA
    Black 15' Tacoma DCSB 6spd
    maybe some pieces of wood and bottle jacks. if you can get a brace between the inside of the wheels and jack them separate that might help
    EDDO and TedG like this.
  8. Jun 5, 2023 at 2:38 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    If you have a Hi Lift, you can probably push them apart using that and a 2 x 4.
  9. Jun 5, 2023 at 2:42 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    If it is the rear tires just hit it with a sledge hammer from the back side of the side wall. Had this happen to me on the rears all the time.
    uploadadventure likes this.
  10. Jun 5, 2023 at 2:43 PM
    Clearwater Bill
    Billy
    Largo Florida
  11. Jun 5, 2023 at 2:44 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    use a screw jack like from a subaru with 2 2x4's screwed together and push on the wheels. PB blaster the snot out of them and then a dead blow hammer on the side of the wheel opposite the jack...
    no shocking just hitting the tires, need to hit the wheel...
  12. Jun 5, 2023 at 2:49 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Put the lugs on just a few threads and take a drive around the block and they should pop loose.
    Evostaco, clip, RugglesTarlek and 5 others like this.
  13. Jun 5, 2023 at 3:16 PM
    EngineerMatty
    To answer multiple posts, No wheel spacers, completely stock truck, these rims were made for the tacoma.. the site has nearly 2000 posts about FN wheels I believe.
    I only have a floor jack. Left sides are frozen front and rear.
    I didn’t want to damage the rim by smacking the rim with the sledge so I was hitting the side wall in multiple places
    Maybe driving a bit with loose lugs but not confident about that option.
    Wheels been on over 1 year and was taking in for service and shops never mentioned anything. Trust me once I get them off I will wire brush everything and hit the hub faces with antiseize
    I do not have a torch to heat
    3JOH22A and KLiK like this.
  14. Jun 5, 2023 at 3:17 PM
    EngineerMatty
    I can’t picture what you are describing sorry. I do own a subaru btw
  15. Jun 5, 2023 at 3:21 PM
    EngineerMatty
    I may see what you are saying but just don’t have bottle jacks at the moment
  16. Jun 5, 2023 at 3:24 PM
    TedG
    TedG Active Member
    Ted
    Shenandoah Valley
    2019 TRD Offroad
    Stock
    I dealt with this last week. I tried prying, beating, etc. Then I got under the truck and gave it a few good kicks (of course with a jack stand and three wheels on the ground)
  17. Jun 5, 2023 at 3:29 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Usually it's because there is some galvanic corrosion from aluminum wheels on steel hubs.
    I've had a few times in life where this has happened to me.
    What I do is loosen the lugs and drive the car back and forth 10 feet or so until they free from the hubs.
    SR-71A, HWI, michael roberts and 3 others like this.
  18. Jun 5, 2023 at 3:41 PM
    TacoTuesday1
    FL
    if you kick, don't drop the truck on yourself.
    Hammer is to be a deadblow. Whether it hits the tire, half tire half rim, or only rim. That is better than a sledge. HFT has them
  19. Jun 5, 2023 at 3:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you don't have a dead-blow use the sledge and a block of wood against the rim. Hitting the rubber tire won't do shit
    SR-71A, eurowner, HWI and 3 others like this.
  20. Jun 5, 2023 at 4:00 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Another trick is to jack it up one side and apply the brakes both directions with loose lugs.
    AllTacosFloat[QUOTED] likes this.
