Can’t remove wheels, what now
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EngineerMatty, Jun 5, 2023.
  1. Jun 5, 2023 at 4:15 PM
    EngineerMatty
    EngineerMatty [OP] Active Member
    2009 Silver Tacoma Access Cab 4x4 TRD
    Loosened lugs then drove around neighborhood. No luck
    However back and forth applying the brake allowed a pop to the front. Still cannot budge the front. Shot some pb on everything and will try again tomorrow
    Yes I own a deadblow and that didn’t work last week.
  2. Jun 5, 2023 at 4:31 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Out of curiosity, how long have the wheels been on the truck? Have you ever removed them before?
    How loose did you have the lug nuts, they should be backed off pretty far so the wheel has space to break off the hub.
    vssman likes this.
  3. Jun 5, 2023 at 5:38 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Crack the lug nuts slightly loose. Hit the gas and then brake hard all within 20-50 ft (driveway if you can). After a few tries it should pop. Put neversieze on the hub before you reinstall. Good luck.
    SR-71A and SH10151 like this.
  4. Jun 5, 2023 at 6:06 PM
    EngineerMatty
    Probably been 1 year honestly since I rotated them. I don’t put a ton of miles on the truck. The truck sees sunny warm days and heavy rain being in florida.
    Lug nuts were very loose so I allowed plenty of room for the rim to pop off the center hub
  5. Jun 5, 2023 at 6:08 PM
    EngineerMatty
    Did this today in driveway and front popped but still can’t budge. Lugs completely off btw. Rear didn’t move or make a sound. Ill try again later this week
  6. Jun 5, 2023 at 6:17 PM
    bigmw
    bigmw Not-So-Well-Known Member
    Northeastern Ontario
    2016 Blue DCSB Sport 4x4, manual transmission
    Bunch of different mods
  7. Jun 5, 2023 at 6:22 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Many years ago, I used to work at a garage and we had this issue. We put the car on the lift, loosened the lug nuts, got the car up to 40 and slammed on the brakes. Wheels popped off after a couple of hits. Try on Jack stands if all else fails.
    Edit: you may damage the wheel studs doing this. Look closely at the threads for damage.
  8. Jun 5, 2023 at 6:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The heat isn't going into the tires. I'm just talking about removing the center cap and getting some heat on the hub center. But they're nice wheels, it's not really a good idea
  9. Jun 5, 2023 at 6:45 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Hitting the sidewall with a sledge risks damaging the sidewall. I wouldn't do the heat thing either. Loose lugnuts sounds sketchy AF.
    What I've had luck with in the past is sitting on the ground and kicking the outer edge of the rim, one side then the other. Rotate the wheel if needed. It usually only took a couple of kicks.
    uploadadventure likes this.
  10. Jun 5, 2023 at 6:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Use a ratchet strap to strap a piece of 2x4 to the rim. Through the spokes.
    The longer the 2x4 the better. Then pry the rim off. Just like a breaker bar.
    If you have buddy to help, have him hit the rim with a hammer to help “shock it” loose.
    po35042 likes this.
  11. Jun 5, 2023 at 7:01 PM
    bigmw
    That's exactly how you pyrolyse the tire - by heating the wheel, you create a powerful explosion
    I didn't realize how dangerous that is before either
  12. Jun 5, 2023 at 7:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Then let the f--kin air out of the tires :notsure:
    I dunno, I'm just throwing ideas out. If I got some stubborn metal at work I use the torch all the time with great results
    Can't be anymore dangerous than these guys saying to loosen the lugnuts and drive around hitting the brakes
  13. Jun 5, 2023 at 8:07 PM
    TnShooter
    Deogee
    STOCK
    I’m with you man.
    The way I see it, the wheel is stuck.
    The wheel needs to come off.
    So, try things until the wheel comes off. And I’ll be the first to say, Trying “dangerous” things is certainly an option.
    I’ve done lots of dangerous things to get a job done. Sometimes it works, other times it doesn’t.
    If I were OP, I would get the wheel off sooner than later.
    At some point the tire will need changed, or brakes…..ect.
    Cosmetic damage or not, I’m getting that wheel off.
    Better to get it off now than wait until it “has to” come off.
  14. Jun 5, 2023 at 8:18 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    Try taking the centercaps off if possible and if thats not an option youll have to go from the back side of the wheel and maybe also in through each lug hole. Spray a generous amount PB Blaster or Open&Shut in there let it sit for a few min and go around the inner wheel/tire with a block & sledge. Give it a go a few times and if that fails, mule kick…
    Apply anti-seize to the hubs, clean the wheels, & reassemble.
  15. Jun 5, 2023 at 8:55 PM
    #35
    chevybass
    chevybass Well-Known Member
    NC
    2009 Tacoma TRD Sport - Pyrite Mica
    I purchased my truck when I lived in FL and had the same issue with all four wheels. Seems the previous owner drove it on the beach and the salt water "welded" the aluminum wheels to the steel hub. A couple of wheels broke free after a lot of beating with a dead blow, but it took a couple of days for the other two....spraying them with everything imaginable and letting it soak for hours. I used a large hammer with 2x4's against the rims and they finally broke free. Afterwards, I used a wire brush grinder to clean the corrosion from the back of the wheels and the hubs and put anti-seize on them. Never had another issue. I actually just replaced them with new wheels a couple of months ago. Good luck!
    TnShooter likes this.
  16. Jun 5, 2023 at 10:06 PM
    #36
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    I had the same issue on my FJ cruiser.
    Bolts sized had to use a breaker bar and a 6ft pipe to get it in done.
    Then the rim was sized to the hub/axel whatever.
    Had to use penetrating fluid on the 0.0001mm gap, hitting it with said pipe, then gently lowering the jack where some of the car weight pushed the wheel out and unsized itself
    winkel likes this.
  17. Jun 6, 2023 at 5:10 AM
    #37
    bigmw
    Heating a rim with a tire mounted is EXTREMELY dangerous
    "Under no circumstances should a rim be heated while the tire is still mounted, such as by welding or the use of cutting torches, or any other procedure that would cause extreme heat. The tire must be removed from the rim before this type of work is conducted."
    https://www.ontario.ca/page/alert-tire-explosion-pyrolysis
    By heating the rim you are essentially creating a bomb that can explode either immediately, or for hours later
  18. Jun 6, 2023 at 5:33 AM
    #38
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    At first read I had to check what day it was, to make sure yesterday wasn’t Friday.
    but after reading the whole thread, I was thinking “oh yes… aluminum on steel, what a pain”
  19. Jun 6, 2023 at 5:56 AM
    #39
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    You just need the lug nuts a thread or two loose - not completely off - if you're trying to drive it to loosen it.
  20. Jun 6, 2023 at 6:11 AM
    #40
    TSmalls89
    TSmalls89 Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
    Mark all 4 tires with chalk design, bolt all back on, drive to your nearest shop and let them do it. Confirm chalk designs moved after to make sure they did actually rotate them lol
