Can’t remove wheels, what now
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EngineerMatty, Jun 5, 2023.
  1. Jun 6, 2023 at 6:30 AM
    #41
    EngineerMatty
    EngineerMatty [OP] Active Member
    2009 Silver Tacoma Access Cab 4x4 TRD
    Yes they were on and loosened when I drove around. I removed them when I went back and forth in my driveway. It didn’t matter. These are seized on well
  2. Jun 6, 2023 at 6:31 AM
    #42
    EngineerMatty
    My last resort I will or just watch them from the viewing window at a shop
  3. Jun 6, 2023 at 6:31 AM
    #43
    EngineerMatty
    Yeah no shit I agree
  4. Jun 6, 2023 at 6:33 AM
    #44
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    pull the valve stem core out so it can't build pressure inside. Wait until it cools down, reinstall the valve core and fill it with air
    winkel and stickyTaco like this.
  5. Jun 6, 2023 at 6:46 AM
    #45
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    For the front, loosen the lug nuts by one or two threads. Park the truck next to a curb. Put a blanket or something down to protect your wheels if needed. Get the tire right next to the curb, turn the wheel back and forth against the immovable curb using the power steering to push the wheel back and forth. It should pop.
    A bit tougher to do something like this for the rear, but I've had luck with the same one or two threads loose on the lugs, but with ALL OTHER LUGNUTS TIGHT!!!! Find a deserted road and go from 40mph, slamming on the breaks. Then in reverse, slam on the brakes. If that doesn't work, try violently sawing the wheel back and forth to move the weight of the truck around and cause the wheel to pop.
    I've never had an issue using these methods. Again, do ONE WHEEL AT A TIME. All other lugs should be torqued to spec so you don't damage the studs.
    EngineerMatty[OP] likes this.
  6. Jun 6, 2023 at 6:56 AM
    #46
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    With the lug nuts firmly tightened you can drive through a series of panic stops and heat up the rotor which should transfer some heat to the area where the wheel mounts. That may not help much with the rear wheel but it is a safe way to apply a bit of heat. Otherwise keep hitting it with PB Blaster and using a 2x4 or even better, a 2x6 on the backside of the rim to avoid damage to the rim. With the 2x6 there you can give some nice blows to the rim without causing any damage.
  7. Jun 6, 2023 at 7:47 AM
    #47
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Try an air hammer or needle scaler on the hub face, let it rattle for a while?
  8. Jun 6, 2023 at 1:31 PM
    #48
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    You can use a curb on the rears too. Get the front up the curb and the rear you want to pop parallel as you can and up against. Loosen the rear lugs a thread or two then try to drive the rear wheel up the curb real slow and at a very shallow angle. This will wedge the curb face against the tire face and lever it off.
    You'll scuff the sidewall, but having done it twice on an old POS, not bad enough to actually damage the tire.
    shaeff[QUOTED] likes this.
  9. Jun 6, 2023 at 1:41 PM
    #49
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I have a friend that always puts a little anti-seize when installing his wheels, I’ve never done this but he has for years
  10. Jun 6, 2023 at 1:49 PM
    #50
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    You guys are telling me this threads been here an entire day and no one said to hit it with your purse yet???
    Seriously though, put all the wheels back on and just take it somewhere for a "tire rotation." If you take it to any shop thats been in business more than 3 years, it won't be their first time encountering this. Sounds like you're just gonna end up ruining your studs either way.
  11. Jun 6, 2023 at 1:50 PM
    #51
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If they are that stuck heat may be your only option, I've have good luck getting siezed bolts out of aluminum with heat as aluminum expands quite alot when heated vs steel. I'm not talking red hot but just enough heat to expand it, aluminum dissipates heat very quicky so as long as you don't get carried away with the torch you aren't gona hurt anything.
    Mine were stuck the first time I rotated them although not that bad (aluminum wheel steel hub it's inevitable), I sanded the corrosion off with sandpaper and put antisieze on the hub and on the part of the wheel that goes over the hub and they c9me right off every time now. I reapply it every few times I have them off.
    SR-71A, shaeff, b_r_o and 1 other person like this.
  12. Jun 6, 2023 at 6:02 PM
    #52
    shaeff
    Hudson Valley, NY
    Good call.
  13. Jun 7, 2023 at 5:18 PM
    #53
    EngineerMatty
    Ok I got the front to pop this evening backing up and turning the wheel while applying the brake. Mind you the day before I resprayed the lugs, hub and behind the hub, drove around with the lugs a few threads loose and went forward, backward in my driveway a bunch of times. Once I got that one off I didn't see too much heavy corrosion, however inside the rim was quite a bit of aluminum burrs and slightly rolled edges on the holes. I wire brushed, used a dremel, and some steel wool to clean the rims (lug holes and hub hole) and wire brushed the studs and hub face. Threads looked great, no damage. Afterwards I put antiseaze on the hub face, hub center boss, a light coat on the hub hole in the rim and very light coat on the lug holes.
    The rear I am soaking again tonight. I don't have any curbs in our neighborhood...no tree lawns sidewalks so I had to improvise with placing 1-2 2x4s on the ground and I jacked the truck up, slid the wood underneath the inner edge of the tread, then dropped the jack. I did this multiple times and moved the wood block to the outside of the tire too....still wouldn't budge. I drove the truck through my neigborhood a bit to try and get something to happen but nothing has worked yet.
    I will try again tomorrow. I haven't tried the purse yet...my wife packs alot in hers..maybe that would work... I like the bottlejack idea. I may try to purchase one tomorrow as I do not have one of those...just a floor jack and jack stands. I'm definitely not using a torch/heat method or even considering it.
    Torspd and ssd2k2 like this.
  14. Jun 7, 2023 at 5:25 PM
    #54
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    I saw a tow driver ram into the stick wheel with the tread face of another wheel/tire combo to knock a stuck rim loose. That'd prevent any chance of denting the wheels.
  15. Jun 16, 2023 at 6:01 AM
    #55
    EngineerMatty
    So I wanted to summarize how I got the most stubborn rim off. I jacked the rear of the truck up (both rears off the ground) and made sure I had a sledgehammer with a rubber coating. I proceeded to hit the inside edge of the rim and rotate the tire in multiple spots and kept hitting. I finally got it loose but it was very hard to remove. As it turns out it was not due to corrosion. The rim and hub face had hardly a trace of evidence. What was apparent were shavings of aluminum on the steel threads. The holes on the rims have closed up slightly due to rolled burrs inside of some of the holes. Has anyone experienced this before? I only had a dremel tool available and not many bits to select from to try and grind the burrs away. I couldn't find a small enough wire brush at any big box stores. Anyone have suggestions how to open the holes up again? Do I need to take it to a shop so they can ream the holes? Maybe I can hand ream them?
  16. Jun 16, 2023 at 6:09 AM
    #56
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Sounds like whoever put them on last threw them onto the threads and drove the wheel on by tightening the lugs, rather than seating it on the hub and then tightening. That's the only way I can think of that would cause the stud holes to get so chewed up.
    Tacomas use hub centric wheels, so as long as the holes clear and you can seat the wheel back on the hub, no need to have the holes precision reamed or anything. Get the wheel on the hub, hold it steady if it wants to fall off, and hand seat the first two or three lugs until they're on far enough to hold the wheel on the hub.
    SR-71A likes this.
  17. Jun 16, 2023 at 6:17 AM
    #57
    EngineerMatty
    Well the reason I am asking about opening the holes back up is because a few days after I reseated the rim properly, I still had to hammer the rim back off with a sledge. That's not normal, it should never be that difficult after only a few days.
  18. Jun 16, 2023 at 6:20 AM
    #58
    Off Topic Guy
    Out of curiosity, are you using stock lug nuts or aftermarket with your aftermarket wheels?
    Dm93 likes this.
  19. Jun 16, 2023 at 6:23 AM
    #59
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Post a pic. I cant see how the stud holes could interfere that much to cause such a big issue. I've worked on a few cars with stuck hub-centric rims and it never looks as bad as you would expect in the way of corrosion at the wheel / hub interface.
    What Im saying is you should lube that area, regardless. Anti seize, fluid film, whatever. Then try again and see if that helps
  20. Jun 16, 2023 at 6:25 AM
    #60
    EngineerMatty
    Aftermarket. They are the splined lug nuts designed to fit with the FN Five Stars. I purchased them from the same source as the rims
