Can’t remove wheels, what now
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EngineerMatty, Jun 5, 2023.
  1. Jun 16, 2023 at 6:27 AM
    #61
    EngineerMatty
    EngineerMatty [OP] Active Member
    2009 Silver Tacoma Access Cab 4x4 TRD
    I'll post a photo the next time the rims are off, probably not anytime soon. I lubed with anti seize once the rims were off.
  2. Jun 16, 2023 at 6:50 AM
    #62
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Power drill with stepped drill bit (as they are available in diameters larger than 1/2") would be the quickest.
    Dremel with coarse carbide high-speed cutters like this would work too but take a bit longer. Buy a few packs from Home Depot as they get worn down.
  3. Jun 16, 2023 at 7:02 AM
    #63
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The holes are closing up? Are the lugnuts getting over-torqued?
    We need pics
  4. Jun 16, 2023 at 7:02 AM
    #64
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Thought you said you were running stock everything? Just because aftermarket wheels say they fit doesn't always mean they do
  5. Jun 16, 2023 at 7:12 AM
    #65
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    1st post states wheel type, but now knowing he used the correct lugs for the job, I'm left scratching my head. Either the install was so janky they messed up the wheels in the process, or install was so janky, the wheel messed itself up over the course of time, or its just a different wheel spec altogether that somehow got manipulated on. I thought the FN's only came in one size though, so who knows.
  6. Jun 16, 2023 at 7:14 AM
    #66
    EngineerMatty
    What I meant with stock in my post #13 is no special wheel spacers. The tires and rims are only thing not stock.
    The link below is what I followed when I first purchased these rims. Yes, again they are made for the Tacoma.
    Lugnuts are torqued 75-80 ft-lbs as the manufacturer recommended also.
    https://www.tacomaworld.com/threads...new-wheel-from-fn-wheels.261242/#post-6374585
  7. Jun 16, 2023 at 7:16 AM
    #67
    EngineerMatty
    I think over-time multiple different shops torqued the lugs using impaction equipment probably to different torque specs (which is not recommended per what the manufacturer originally told me) and I suspect they didn't secure the rim on the hub first before running the lugs tight at one point in time. Impossible to pinpoint the root cause but what's done is done.
  8. Jun 16, 2023 at 7:17 AM
    #68
    SR-71A
    Zack
    Southern Maine
    Ahh yup I missed that part.
  9. Jun 16, 2023 at 7:21 AM
    #69
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
  10. Jun 16, 2023 at 7:28 AM
    #70
    EngineerMatty
  11. Jun 16, 2023 at 8:30 AM
    #71
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Don't bother with a battery terminal brush lol. If the burrs are substantial enough to cause issues with wheel fitment, a finger-operated brush won't do anything.
    SR-71A likes this.
  12. Jun 16, 2023 at 8:31 AM
    #72
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm having a hard time understanding how some burrs can lock a wheel onto a hub. I still think it's a center bore fitment issue
    SR-71A likes this.
  13. Jun 16, 2023 at 8:35 AM
    #73
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Cut a slit in a dowel, shove some 36 grit sandpaper in and chuck it in a drill. Let it eat.
    winkel likes this.
  14. Jun 16, 2023 at 9:06 AM
    #74
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Get a conical or "acorn" shaped grinding stone for a drill and the hardest part of deburring aluminum could be if the metal clogs up the grinding face of the stone where it's contacting.
