Can 33x13.50 15s fit on a toyota pickup?
Discussion in 'Toyota Trucks & SUVs' started by 1999tacotrd, Jul 7, 2009.
  1. Jul 7, 2009 at 7:43 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    Hi i found some of these tires for $100 for the set and i bought them and they installed them but they didnt fit the fronts rubed but backs where fine so i was wondering if i could get some dif 15" rims that are deeper then my stocks so the tires will set out more and not rub.
  2. Jul 7, 2009 at 7:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah...you can get wheels with a different offset..or you can buy wheel spacers for the front. check out wheelersoffroad.com...they have some wheels that will work......look at their type-b wheels.
  3. Jul 7, 2009 at 8:04 PM
    1999tacotrd
    So i would need 15x8 or 15x10? and on the spacers how many can u use at once like could u use 2 or only 1 on each side?
  4. Jul 20, 2009 at 9:36 AM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Holy cow... You can clear 33's?! How much rub are we talking here? Just on the inside or on the inner fender too. I have a 98 and I clear 31's with the drivers side front rubbing the inner fender. And to answer the question, you could double up on the spacer but your better off just to get whatever size you need and just run one. They make em in pretty much any size.
  5. Jul 20, 2009 at 10:03 AM
    1999tacotrd
    I bought some 10" rims at a slavage yard and they dont rub a bit :) the turck has a 6" body lift so it has plenty up and down space.
  6. Jul 20, 2009 at 10:12 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Ahhh... I see. I never heard the body lift part. Yeah still you're gonna need some offset to get those 13.50's to clear the spindles.
