Can a 1.5" AAL be modified into a 1" AAL?
Discussion in 'Suspension' started by BenWA, Jan 22, 2011.
  1. Jan 22, 2011 at 7:27 PM
    BenWA
    BenWA [OP] Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    Such as by shortening it/cutting off some length from each end? Or would shortening it muck up the ride quality/stiffness somehow?
    Trying to figure a way to get .75" or 1" rear lift without using blocks. So far none of the spring shops that I have called sound like they know what they are doing or talking about regarding making custom AAL's for a Taco, so that doesn't seem to be an option.
    So I wonder if there is a way to modify a 1.5" AAL to provide slightly less lift. Anyone have knowledge or experience with this?
    p.s., I'm running 5100's set at .85" in front, which is why I don't want a full 1.5" in back.
  2. Jan 22, 2011 at 7:40 PM
    armyairforce89
    armyairforce89 Active Member
    Illinois
    2010 5-lug SR5
    Ready Lift SST Lift Kit, Fog Lights, Aluminum Diamond Plate Tool Box, AFE ProDry S Air Filter, UltraGuage, BF Goodrich Long Trail T/A 235x75x15's
    Just use the 1.5, after a few months it will settle anyway. Might start out a little higher than you want, but in the end it will settle in where your aim is.
  3. Jan 22, 2011 at 9:55 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    One half of an inch doesn't really matter does it? FWIW, I would not feel comfortable altering the AAL.
  4. Jan 22, 2011 at 10:31 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    Leave the aal at 1.5 and it will settle down after a while and if it sits to high in the rear just lift the front little higher
  5. Jan 23, 2011 at 8:38 PM
    BenWA
    Seattle @ 0.9 Mach
    Is there any way I could change the arch radius of a set of 1.5" AAL's by compressing them somehow to make them closer to 1"?
    Of course I would have no way of knowing how much to flatten them to give the desired result.
    Guess I'll just run 1.5" AAL's and sit a little more ass-high than I want to. :(
  6. Jan 23, 2011 at 8:46 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2007: Avid sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, blisten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scanguage, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, TRD skid plate, light pods mounted in front bumper
    have a fat chick sit in the bed :p
  7. Jan 23, 2011 at 8:57 PM
    BenWA
    Seattle @ 0.9 Mach
    Would that significantly reduce my mpg's?
  8. Jan 24, 2011 at 4:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    In most cases, if the AAL is advertised to give you 1.5" - then it'll give you approx 1.5" after settling. When you first install it....it could give you 2" or more.
    Put 200lbs in the bed for a month and that'll help it settle down.
    Besides that..... 1/2" isn't much at all. You won't even notice it.
    Arching leaf springs can be done but its expensive and (for the most part) they don't hold their shape over time and can sag. Re-arching an AAL would be even worse...and the end result might be worse than if you left them alone.
  9. Jan 24, 2011 at 7:54 AM
    BenWA
    Seattle @ 0.9 Mach
    Crap. I def don't want 2"! Do you happen to know if there are certain AAL makes that underexaggerate vs. overexaggerate their claims of lift height?
  10. Jan 24, 2011 at 8:00 AM
    Bobcat
    Bobcat Well-Known Member
    Montana
    Get a 34" inch one from Fat Bobs Garage and use a cutting torch to take a few inches off each side. That should accomplish your goal. Wheeler's aal is only 24 inches so even if you had to cut off as much as 10 inches it would still be ok.
  11. Jan 24, 2011 at 11:34 AM
    BenWA
    Seattle @ 0.9 Mach
    Thanks for the info Bobcat.
    I decided to order the wheelers 3 leaf aal, as I have done some searching and read a number of posts that claim that the 3 leaf typically provids slightly less than 1.5" for double cabs. We shall see. Worst case scenario is I have to put a fat chick in my bed.
  12. Jan 24, 2011 at 11:37 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Why not just raise the 5100's to 1.75? Seems easier and cheaper (costs nothing)...
    When in doubt use the KISS method.
  13. Jan 24, 2011 at 12:10 PM
    BenWA
    Seattle @ 0.9 Mach
    I wish I could. It's a long story, but I have front diff vibe issues (shot diff bearing) and 1.75" would make them unbearable. I have minor vibes at even .85" but they are slight and intermittent enough that I can live with them.
  14. Jan 24, 2011 at 12:19 PM
    macgyver
    Brad
    Canton, GA
    How do you know? Are you assuming here or have you tried?
  15. Jan 24, 2011 at 12:22 PM
    BenWA
    Seattle @ 0.9 Mach
    I'm assuming.....but I had severe vibes at 2.5" and currently have minor vibes at .85", so I'm guessing that 1.75" would be something in between. I definitely don't want to have worse vibes than I have right now.
  16. Jan 24, 2011 at 12:28 PM
    macgyver
    Brad
    Canton, GA
    I have minor vibes at 2.5. Are you sure they're coming from the front? I can feel mine in the floor/seat which means mine are coming from the rear end/driveshaft
  17. Jan 24, 2011 at 1:23 PM
    BenWA
    Seattle @ 0.9 Mach
    Yeah, I'm sure. I haven't done anything to lift the back yet and the vibes appeared immediately after lifting the front, and then disappeared immediately after I temporarily unlifted the front back to stock ride height.
    These are the types of vibes that disappear immediately upon switching to 4Hi -- classic front diff diagnosis.
    I may try out the 1.75" setting when I have some spare time. One of the main things preventing me from trying it is the cost of an alignment.
  18. Jan 24, 2011 at 6:17 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Bilstein 5100's with OME 885 X,top plate spacers,taco lean spacer,All Pro Expo's in the rear,installed fog lights,installed intermitent wipers,IPF off road lights,ARE topper with 5 ft. Hi-Lift Jack,first aid kit, fire extinguisher installed inside,Sway a Way front sway bar,Westin Brush Guard,air box mod,Mag Lite Mod,Relentless CB ant. Mount, DX 959 Galaxy CB,Go Rhino nerf bars,Duratrac 235-85-16's on TRD OR wheels,
    I put 5100's on mine, set at 2.5 in the front and it gave me the exact lift as claimed. Then we put the non tsb ToyTec AAL in the rear,it should have given us a 2 inch lift, but instead,it ended at 3.75 inches. That was with an ARE contractor cap, all my work equipment, and two fiberglass ladders on top, I figure over 500 pounds total. So for the last month I added 200 pound of sand bags to the tailgate area, trying to get the darn things to settle in. I just measured earlier tonight, still above 3.75 total lift on that AAL, any ideas how long it takes to settle, I hate running around with 200 pounds of sand in the back.
  19. Feb 10, 2011 at 7:29 PM
    BenWA
    Seattle @ 0.9 Mach
    Hey macgyver, I bumped my struts up to 1.75" tonight... vibes are slightly (but not substantially) worse than they were at .85". I definitely can live with them. :cool:
    Plus I haven't gotten an alignment yet, so they may be slighlty better after I get the alignment done tomorrow.
    Thanks for the kick in the butt to give that height setting a try. :D
