Can a 2009 TRD Off-Road suspension be easily improved upon?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Jun 21, 2022.
  1. Jun 21, 2022 at 4:36 PM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    I'm thinking about replacing/upgrading my Bilstein rear shocks and front coil-overs to improve the on-road ride of my 2009 TRD Off-Road.
    Is this doable/worthwhile? Are there any products out there that will render a big improvement?
    I guess what I am hoping to do is attain the ride quality of a 2022 Tacoma (or better).
    FWIW, surprisingly, with 119,000 miles on the original shocks, coil-overs, and progressive-rate springs, everything still seems to be working, and AFIK, nothing is "shot".
    Thanks for any replies.
  2. Jun 21, 2022 at 4:43 PM
    UnloadedRex
    UnloadedRex Tire and alignment guy
    Oscar
    Jacksonville, FL
    2007 DCSB Redneck Trophy Truck
    Bilsteins 5100, dobinsons coils, Apex Badlands winch, and lots of stickers
    As many on here will tell you: put the shocks from a 3rd gen onto your truck. I have 3rd gen TRD-offroad shocks on my 2007 Prerunner and they ride great. So buy a used low mileage set of 3rd gen takeoffs and slap those on your truck and you’ll have pretty much that exact ride quality you’re looking for.
    Also make sure to check your tire pressure, if it is way over the recommended amount (found in your doorjam sticker) then air it down to that number or even slightly below it. As long as you’re not doing any heavy hauling you’ll have better on road performance with the suggested tire pressure.
    asuchemist likes this.
  3. Jun 21, 2022 at 4:46 PM
    Plasmech
    Thanks.
    Do you happen to know the Bilstein part numbers of the 3d gen coil-overs and shocks?
  4. Jun 21, 2022 at 9:21 PM
    UnloadedRex
    Oscar
    Jacksonville, FL
    Personally I would try finding used ones on Facebook marketplace, Craigslist, or even here on TW. Getting them used saves you a ton of money and headache trying to find part numbers.
    ZColorado and wi_taco like this.
  5. Jun 22, 2022 at 4:44 AM
    Plasmech
    Thanks. And any of the 3rd gen years are compatible with my 2009?
    (Hard to believe so little changed over such a long period)
  6. Jun 22, 2022 at 5:46 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Any 3rd gen components will work, including UCAs but excluding LCAs.
    UnloadedRex likes this.
  7. Jun 22, 2022 at 4:09 PM
    UnloadedRex
    Oscar
    Jacksonville, FL
    It is Toyota after all, if it ain’t broke don’t fix it until the market forces us to.
