Can a 2WD 4cyl stock 2021 Tacoma handle ANY Ocotillo Wells trails?
Discussion in 'Off-Roading & Trails' started by TacoSRSX, Feb 26, 2021.
  1. Feb 26, 2021 at 2:29 PM
    TacoSRSX
    TacoSRSX [OP] Well-Known Member
    Martin
    Ventura County / San Fernando Valley - CA
    2021 MGM SR 2.7 2WD SX
    Ionic Pro 4" tube steps Desert Does-it Seat Jackers ECT PWR always on Kicker Tweeters replacement Tyger roll-up vinyl cover Bed mat
    I looked up Gorman off-road trials at Hungry Valley and saw that a lot of the "easy" trails are going up on high inclines so now I'm looking at Ocotillo Wells... I have a bone stock 2021 SR Access Cab 4cyl 2WD and am wanting to take it on some dirt roads and easy trials if Ocotillo has any?
    Thanks
  2. Feb 26, 2021 at 2:37 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    There are plenty of trails/ roads out there that a 2wd truck can handle. In the OHV area there’s pole line road and most of the washes (San Felipe) are relatively easy as long as you air down and carry some momentum. There’s also some other trails that are non OHV outside the park area. Just use common sense and try to avoid going it alone.
  3. Feb 27, 2021 at 9:15 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Is this a Prerunner or a 5 lug?
    Edit: just saw your avatar so I'm assuming it's a prerunner.
    Prerunners are fairly capable off road. Best way to find out HOW capable is to go try it. Have a friend with a 4x4 nearby to help, though...
  4. Feb 27, 2021 at 9:21 AM
    TacoSRSX
    Martin
    It's just a base SR 4cyl with the SX exterior package so the rims are different and I do think it rides a bit higher.
  5. Mar 1, 2021 at 5:17 AM
    PRBond
    PRBond Well-Known Member
    Patrick
    Columbus, OH
    04 TRD PreRunner
    3" ToyTec suspension kit, AEM Air Intake, Uniden 510 CB, 265 X 75 X 16 BFG AT's
    A 2WD truck can absolutely have some fun out in Ocotillo Wells. I grew up in East County San Diego and Ocotillo Wells was my off road camping and wheeling playground for years. I've seen regular passenger cars out there on power line road. There are places out there where the sand can get a little deep which you might need to get pushed/pulled out of. Be sure to air your tires down a bit and I would recommend you go with someone else for the first time who knows the trails (and can potentially pull you out if you get stuck.)
  6. Mar 1, 2021 at 5:29 AM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    You can do most of Anza B in a prerunner...
  7. Mar 1, 2021 at 6:36 PM
    TacoSRSX
    Martin
    I don't believe a base model 4cyl SR qualifies as a prerunner
