Can a 3rd Gen manual be push started?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThreeBeers, Mar 9, 2022.
  1. Mar 9, 2022 at 6:24 PM
    ThreeBeers
    ThreeBeers [OP] Well-Known Member
    Ron
    2020TRDOR
    Probably a dumb question but it would not surprise me if it couldn’t.
    Have government safety regulations made this impossible?
    just one of these things that popped in my head.
  2. Mar 9, 2022 at 6:46 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
  3. Mar 9, 2022 at 8:01 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    It can been done. Requires the use of the clutch start cancel button.
  4. Mar 9, 2022 at 8:07 PM
    Bishop84
    Bishop84 Well-Known Member
    Yup, try shutting it off by holding the start button while rolling, then key on with no clutch, and re-engage the gear. Basically a push start.
    Be careful if you haven't done something like this before.
    Tacospike, shakerhood and Junkhead like this.
  5. Mar 9, 2022 at 8:47 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The clutch start cancel button just bypasses the clutch switch to engage the starter in gear.
    With a push start, the driveline is turning over the engine, not the starter.
    mtip likes this.
  6. Mar 9, 2022 at 9:16 PM
    BlarBlarjosh
    BlarBlarjosh Well-Known Member
    Josh
    Southern California
    I thought you meant bump start, but I guess seeing everyone else's answers I'm probably wrong.
    If not, yes you can bump start. As for having a button to push to start, I have no clue..
  7. Mar 9, 2022 at 9:59 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Yes...you can bump fire a M1 Garand rifle too!
    TXpro4X4 and ktbell444 like this.
  8. Mar 10, 2022 at 3:42 AM
    ThreeBeers
    Ron
    2020TRDOR
    Thanks, it was just a thought that popped in my head. I would try it myself if I had access to a MT 3rd Gen. Back in the day you could put off replacing a battery if you remembered to park facing downhill. VW Bugs were the easiest if no one was around to help push.
    shakerhood likes this.
  9. Mar 10, 2022 at 6:05 AM
    andrwoo
    andrwoo Well-Known Member
    Andrew
    East TN
    2020 Tacoma TRD Offroad Double Cab shortbed - Quicksand
    Yes. I have 2020 OR manual. I have done it a couple times. No need to worry with clutch start button. Luckily I was facing down hill. Just put it in second, get her rolling and pop. Started right up.
    TRD75 likes this.
  10. Mar 10, 2022 at 7:29 AM
    CT Yankee
    CT
    Yes, I understand that the driveline is turning the engine over. But doesn't a manual require the clutch pedal to be depressed to the floor BEFORE you can key start? By using clutch start cancel button you bypass that 'safety' feature.
  11. Mar 10, 2022 at 7:31 AM
    adamceckhardt
    adamceckhardt Well-Known Member
    You're not using the key to start it in this scenario.
    Speedfreak likes this.
  12. Mar 10, 2022 at 7:50 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    If you are push starting the truck, then you do not have use of the starter for some reason, like a weak battery. Since the Clutch Cancel bypasses the clutch switch to activate the starter, it is as useless as the starter in a weak battery scenario.
    Edit: Another thing to note, you will only start the engine if you have enough battery capacity to create a spark when the engine turns over...
  13. Mar 10, 2022 at 8:01 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I would get a good roll and pop it in 2nd gear, not 1st.
  14. Mar 10, 2022 at 8:12 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Back about 1987 I had a neighbor with a almost brand new Chrysler Laser (if you don't remember it you aren't alone), the starter went bad and a new one wasn't available for a several days. He was bummed, it was his only car.
    I showed him how to start it by rolling down the slight grade we lived on. Every morning this suit and tie guy (he had a good job) would roll down the grade and motor off to work, apparently he found a grade to park on at work too. Thanks for the laugh, I haven't thought of that in years.
  15. Mar 10, 2022 at 9:05 AM
    jrberry55
    jrberry55 Well-Known Member
    This makes me miss my MT. I have been in an AT for years now, but used to do this in all my cars before. I also liked to try and RPM match and shift without using the clutch sometimes. Ah the good ole days.
    6MTPro likes this.
  16. Mar 10, 2022 at 9:06 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    No that would be illegal
