? Can a BlackStone lab oil report tell exactly where this is coming from ? Gen1 5VZFE
Discussion in '1st Gen. Tacomas (1995-2004)' started by Black97v6MT, Sep 2, 2024.
  1. Sep 14, 2024 at 7:36 AM
    #41
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    I wouldn't worry about it much personally. Even with the new picture you just posted. Next time I changed the oil I would drain it into a clean container and then strain it through a clean white rag. If I found anything questionable I would cut the oil filter open and check that. It's hard to tell but in the pictures you just posted that might not be metal, more like sludge or carbon. With that many miles the motor probably has a good amount of oil burned onto everything inside the motor and you are just seeing flakes of it falling off. Have you cleaned the flakes with brake cleaner to see what color they are?
    Black97v6MT[OP] likes this.
  2. Sep 14, 2024 at 4:41 PM
    #42
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Yeah, concur with this statement. At 350K miles the engine is likely to be gradually shedding small bits of carbon/oil sludge, which may also have small amts of normal wear-metals particles in them, on an ongoing basis.
  3. Sep 15, 2024 at 2:37 PM
    #43
    Black97v6MT
    Black97v6MT [OP] 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    What are some actual symptoms to be on the lookout for?
    The Truck is having many odd issues since getting out of major 'surgery' 7 months ago
    I am a novice diy at Best and much of these is over my head I admit
  4. Sep 15, 2024 at 10:35 PM
    #44
    DoktorSlowburn
    DoktorSlowburn Well-Known Member
    Escondido, CA
    1997 White Tacoma SR5
    4runner seats and center console, ARB rear locker, Icon 1.5” AAL, Bilstein 5100 on 4th notch in front (to support future tube bumper & future winch), 4600s in the rear. In-Cab CB radio. Hella 500 Driving lights. All-Pro Baja front bumper.
    I went down this path with my Mustang. IMO, it’s a waste of time. Blackstone can’t analyze visible metals- if it’s anything larger than microscopic they’ll tell you to have it checked out at a mechanic. Your test will probably indicate high levels of some or other metal, but trust me. It’s just going to give you anxiety.
    Unless the metal shards are concerningly large (which they don’t appear to be) my advice is to monitor moving forward but mostly ignore.
  5. Sep 16, 2024 at 5:54 AM
    #45
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    It helps alot if you've got more experience as there are a bunch of sounds that are perfectly normal but sound bad, or are bad if they're slightly different. I would be listening for any sounds that seem new to you and are loud enough to be questionable. Not real helpful I know, I might get more ideas after I finish this coffee...
  6. Apr 28, 2025 at 4:23 AM
    #46
    Black97v6MT
    iMA0
    tacoLand USA
