Can a CPS Failure cause transmission damage.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DRAWN, Nov 22, 2017.
  1. Nov 22, 2017 at 10:24 AM
    DRAWN
    DRAWN [OP] Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    In mid august I recieved a recall letter from toyota to replace a faulty CPS. After waiting at the dealership for several hours they finish. The next day while driving up to denver(moving for school) the vehicle began to shudder violently, surge and lose power. I was in a pickle because I had all of mine and my GF’s possesions on the ned and I had a deadline to meet. I kept driving, keep in my mind nor warnings showed up on my dash board. Finally I get around and schedule an appointment with stevenson toyota. After I drop off my truck the call me back and say I meed a new transmission because there was a dent in the oil pan, most likely from off roading. Keep in mind I never actually saw the dent. So I pay 5,000 to have a new transmission installed. Great. Everuthings workong fine. One morning my truck won’t start at all and I have to call toyota and have them tow my truck.The culprit? Faulty CPS sensor, Repaired under warranty. Well the other day the truck begins surging and dies on me several times. Os it possible the original transmission damage was actually caused by a failed CPS?
  2. Nov 22, 2017 at 11:14 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What failed in the transmission?
  3. Nov 22, 2017 at 11:21 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    You paid $5,000 for a new transmission on a truck with a warranty, because dealer told you, without ever verifying the dent?!!!!!
    Wow I guess $5,000 isn’t what it used to be
  4. Nov 22, 2017 at 11:35 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    $5000 for a new transmission and install?
    Good lord. Is it gold plated?
    And to actually try to help, I don't see how a faulty CPS could ruin a transmission. But I don't see any actual evidence that your transmission was bad in the first place honestly.
    PROseur likes this.
  5. Nov 22, 2017 at 11:41 AM
    DRAWN
    They told me a dent in the oil pan didn't allow to oil to fully circulate through the transmission.
  6. Nov 22, 2017 at 11:42 AM
    DRAWN
    How much should a new transmission and install run?
  7. Nov 22, 2017 at 11:45 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Trans run about ~3500$ on my last check. Install is where they nab you as its claimed to be a 20+ hour install if memory serves.
    stevotivo12 likes this.
  8. Nov 22, 2017 at 11:53 AM
    aero90
    It varies but it seems like $5k is a little steep. I only really have experience with manual transmissions and I never swap in brand new ones so maybe I am a little out of touch with the real cost. If I actually needed it, I would have sourced one from a yard since they are guaranteed to be low mileage at this point, then had a transmission shop swap it (if you can't do it yourself). But there is a lot more inconvenience to that than having it all done at the dealer. $5k to me might be different than $5k to you, everyone can be in a different place financially.
    But my real question is if the pan was dented.....why didn't they just replace the pan? Typically on an auto transmission you can drop the pan itself, usually have to in order to change the fluid. I'd question why they didnt do this especially if the transmission itself wasn't presenting any other issues (like not shifting, slipping bad, etc). The pan would have been $100 or less I would assume, then probably one hour in labor + fluid.
    shakerhood likes this.
  9. Nov 22, 2017 at 12:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    This is the part where you remember the terms 'second opinion' and 'independent mechanic'.
    They could have been right. Or not.
    So this is a new instance?
    To summarize. Your truck ran fine. You got a recall that replaced the CPS. Your recall CPS failed. Now the replacement for that is failing?
    Or is it the transmission again.
  10. Nov 22, 2017 at 12:49 PM
    DRAWN
    I believe the second replacement is failing as did the first replacement, now I’m stuck wondering if the transmission failiure was at all related to the CPS failing because the sympomts are very similar.
  11. Nov 22, 2017 at 1:18 PM
    Clearwater Bill
    Billy
    Largo Florida
    No.
    Even my vivid imagination can make no correlation between the two.
  12. Nov 22, 2017 at 1:28 PM
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    ‘24 LC250 First Edition, ‘25 TRDOR 6MT, 2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    Dude, the symptoms you were describing sound like a faulty CPS. You need to call Toyota Corporate and open a case file. I would have NEVER had them install a brand new tranny without verifying the damage first.
    If I ever have a problem with my vehicles I make 100% sure I verify what's wrong with them and if it's my fault or is an actual problem with the truck that's Toyota's fault. Just saved myself ~$500 by talking to the dealership warranty rep for an hour because I had a little water leaking into the cab. They thought it was the Prinsu rack I installed but it was actually a seam that wasn't correct from factory. I can't imagine shelling out $5k on something I didn't verify.
    Scott4032 likes this.
  13. Nov 22, 2017 at 3:52 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    so i take it you have over 60k miles on your truck
    otherwise you would have let toyota fix it free.
  14. Nov 22, 2017 at 3:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    They told him it failed from damage he caused. That's not warrantied.
  15. Nov 22, 2017 at 4:16 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Warranty?
  16. Nov 22, 2017 at 4:37 PM
    gearcruncher
    Canadain bumper technician
  17. Nov 24, 2017 at 2:18 PM
    Fullcircle
    Fullcircle Well-Known Member
    2017 Tacoma TRD
    I cannot fathom paying out $5000 dollars without demanding to see the damage- this is crazy to me. And I cannot see how a faulty CPS has anything to do with the transmission no more than a fan belt would.
    jsinnard and Clearwater Bill like this.
