Can a dremel cut up the bedliner?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, May 13, 2010.
  1. May 13, 2010 at 7:57 AM
    ywen
    ywen [OP] Well-Known Member
    I need to take out my stock drop-in bedliner without removing my high-rise topper. I attempted it once and it was a failure. I can remove the bedliner piece by piece if I can cut it up.
    Anyone know whether a dremel can cut thru the plastic bedliner?
  2. May 13, 2010 at 8:00 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    You might be better off with a good set of shears. Do it by hand. Won't slip and cut into the bed.
  3. May 13, 2010 at 8:00 AM
    ywen
    hmm just realized that a high RPM cut wheel will probably just melt the plastic... probably not the proper tool for the job..
  4. May 13, 2010 at 8:01 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    a dremmel should cut it fine, problems will be, it will take forever, you need a cutting wheel big enough to go all of the way through, and be careful if it starts to smoke/melt from the heat (which it will), those plastic fumes can be pretty nasty.
  5. May 13, 2010 at 12:42 PM
    gonathan85
    gonathan85 Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Is it form fit and molded inside of the actual bed? I have an aftermarket bed liner that has "tabs" which lock the liner to the underside of the bed edge rails. I guess I'm just confused as to why you would need to cut it out? If you want to cut it out, I'd suggest something with more power than a dremel...I've learned the hard way that you can burn up a dremel speed control by using it on jobs that it wasn't meant to be used for (aluminum boat work).
    I'd suggest a sawzall....or some type of skill-saw blade cutter.
  6. May 13, 2010 at 1:51 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    with a dremel id be a little worried about the disc blowing up. the stock bedliner should come fairly easy anyway ,ya gotta get a little rough with it but just start from the back and work your way to the front
  7. May 13, 2010 at 8:12 PM
    ywen
    Hey I took the truck to a shop and they lifted the cap off with a forklift and the bedliner was then easily removed...
    I tried to remove it with the cap on the bedrails.. it wouldn't work.. which is why i wanted to cut it up..
