Can a patch be "patched"?
Discussion in 'Wheels & Tires' started by rb11701, Nov 3, 2010.
  1. Nov 3, 2010 at 6:39 AM
    rb11701
    rb11701 [OP] Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I have a bolt go through the tire some months back. Took it in and they put a patch on the inside. Everything was going well. Now that it is colder I am losing air. I would say every week and a half I get my TPMS light on. Fill up with air and all is good.
    My question is, can I take it back in and have them fix the patch or is the tire shot and I need a new one?
    Thanks
  2. Nov 3, 2010 at 6:44 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    maybe you have a nail in the tires
    if its leaking from the same patch you can have it removed
    but should have a plug patch put in it
    also as it gets colder out tires will lose air
  3. Nov 3, 2010 at 5:45 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    yea, they can just take it off and re-do it. Whether or not it needs a plug patch vs a regular patch only depends on the size of the hole. If it's small, there's no reason to enlarge it to fit a plug patch, but if it's a somewhat large hole, you need to plug patch it. Either way whoever patched it the first time fucked up.
