Can a supercharger be tuned?
Discussion in 'Performance and Tuning' started by david90291, Dec 24, 2009.
  1. Dec 24, 2009 at 10:03 AM
    david90291
    david90291 [OP] Active Member
    Oregon
    I recently purchased a 2002 Tacoma with a supercharger. I don't know a lot about the technical issues. I'm getting poor mileage.
    The seller of my truck said that the truck was tuned for off roading but that it could be tuned for city/highway instead. I went to a shop called Dirty Parts in Culver City CA and they said that there was nothing to tune because the computer took care of everything.
    Can someone help me revolve whether the supercharger can be tuned?
  2. Dec 24, 2009 at 10:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    With a piggy back unit, yes it can be tuned. Look into the Uni chip..
  3. Dec 24, 2009 at 10:17 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Dec 24, 2009 at 1:40 PM
    david90291
    Oregon
    How would I know if it already has a piggyback unit? Is there a place to check on the truck? Thanks.
  5. Dec 25, 2009 at 10:42 AM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    Try to remove the right side kick panel and look to see if there is anything plugged into the DLC. It could be wired directly to the computer also. You should see some extra wires that don't look at all OEM and (or)at least a little box.
    Ps. don't go back to that shop. Is obvious they don't know and (or) care much.
  6. Dec 25, 2009 at 12:54 PM
    david90291
    Oregon
    Sorry, but could you please explain the following:
    1. The kick panel is on what part of the engine? I assume the supercharger.
    2. What is the DLC? I would guess it is the computer but I could not find anything on Google.
    Thanks.
  7. Dec 25, 2009 at 2:50 PM
    virgilus11
    kearny, nj
    09 sr5
    Kick panel is inside, front passanger, right foot. It should have a rubber nut or something like that. Unscrew that nut then pull back (not out) toward the rear of vehicle. Be patient and try not to break any clips.
    DLC = Diagnostick LInk Computer. This should be under your left knee. I don't remember well but I believe this a standard for any car. A big plug with a lots of wires-reads OBD2. The computer is on the right side. Once you remove that panel you can't miss that.Try to remove the glove box in the same time. Is a big box with 1000 wires going in- right in the corner. Look to see if there is anything conected to that big box. If there is nothing ??? then look on the outside wall (close to the main ECU) to see if there is anything conected with zip ties. Don't be affraid to open that panel. To tell you the truth I think that the guy that told that-your ECU is set up for Off-road is full of it. Most of the time the ECU is re-flashed to perform good on any situation. I never heard of diferent set up between off road and street. Either way ,, don't worry. Give a call Monday morning to URD and I am pretty sure that they can help you. Your engine is been around for quiet a wile and you should be able to get it right.
    Mean time if you want to help your self try to do a preventive maintenance.
    - change spark plugs
    - change air filter
    - check tires air pressure
    This are only few things may help with your mileage. If your truck have big tires, tarnsfer case and differential gears changed then, there is not much you can do and your mileage is about normal. Try to post a pic with, if any, modifications that you have.Beside the supercharger.
  8. Dec 25, 2009 at 11:39 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    URD can get you fixed right up:
    http://www.urdusa.com/product_info.php?cPath=79_80&products_id=1260518512
    Gadget
