Can a Tacoma tow a 28' travel trailer comfortably
Discussion in 'Towing' started by dblaettler04, Aug 14, 2011.
  1. Sep 30, 2011 at 6:29 PM
    #41
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
    Well, one is like this...
    And the other is like this...
    The 5th wheel is very stable, but so is the Tacoma the way I have it set up. Just came back from a 800 mile trip to the Tetons. On the highway I went through a construction area that had a couple bad bumps over bridges a the weight of the trailer kind of kicks you as it comes out of dips and the ride on old concrete highway is kind of rough. I'm considering air bags. I get about 4" drop from hitch weight (dry hitch weight is 1290lbs.)
    The difference between the two; The Tacoma could use more power to pull that 19' trailer but weight wise for handlling it's very good. If I continued towing with the Tacoma I would get the Supercharger. The Chevy has loads of power, yes it's a diesel. I had no trouble maintaining speed limit on mountain passes. If I replace this truck I would get a 1 ton dually though but for vacation use it does the job just fine. In '96 I pulled a 22' tt with a 1 ton (non dually) on a 3200 mile trip. That truck had a de-tuned 350 (courtesy the EPA regs at the time) which didn't have any more power than the Tacoma and it was about the same feel as the Tacoma pulling the 19' power wise. But I didn't have a WD hitch. Drove that rig on a really nasty highway in Illinois which just bounced the crap out us. Saw a motor home towing a small car that had broken the hitch off the RV on that road.
  2. Jun 26, 2012 at 6:01 PM
    #42
    bdemick
    bdemick Member
    Federal Way, WA
    2006 Tacoma Dbl.Cab 4x4 TRD
    I have a 2006 Tacoma Double Cab, short bed, 4x4 TRD with tow package. I tow a 2012 Keystone Passport 2650BH, empty weight 4960 lbs, tow weight about 5700 lbs and it tows it nicely and at no time does it feel unsafe. The Passport has a spread axel design where the front axel is 10" further forward then most other trailers to better distribute weight and control sway. I use a 4 point Equal-i-zer brand sway control hitch and a Prodigy P2 brake controler. The Tacoma works moderatly hard towing this much, I cruise in 4th gear turning 2500 rpm @ 60 mph. I just towed up 4000 + ft Stevens Pass and it did just fine. At one point the pass gets quite steep and I slowed to 45 mph, but I didn't want to push it. Not the ideal tow vehicle for a trailer this size & weight, but it does ok. Don't push it and take your time. By the way mileage will take a hit. Been averageing 10.5 to 11.75 mpg climbing moderate grades with winding, twisting roads. Straight freeway should be somewhat better.
    Steadfast likes this.
  3. Jun 26, 2012 at 11:10 PM
    #43
    tractng
    tractng Well-Known Member
    For the steepest part of the hill, did you ever use 3rd gear? If so how long (time wise)?
  4. Jun 27, 2012 at 5:30 PM
    #44
    bdemick
    bdemick Member
    Federal Way, WA
    Even on moderate grades I go into 3rd gear and usually hold between 55 & 60 mph, turning 3200 to 3500 rpm. On the steepest grade that I climbed (and I can't imagine a steeper one on a major highway) I went into 2nd gear and held 45mph, turning about 4200 - 4300 rpm, still way below the 5500 rpm redline for this engine. This was only for a short while, spending most of the time in 3rd. As you can imagine, that trip was where I got my worst gas mileage of 10.5 mpg. I still had plenty of throttle left, but I didn't want to push too hard. I love the Tacoma for everyday work & travel and would hate to move up to a full size pickup just to tow the trailer 6 or 7 times a year. I would not sacrifice safety, but so far I'm pleased the way the Tacoma hauls this trailer. It's a beast!! Great truck!!
  5. Jun 28, 2012 at 4:30 PM
    #45
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    bdemick, have you taken your rig to the scales, ready for camping? I think you'd be surprised.
  6. Jun 28, 2012 at 5:05 PM
    #46
    bdemick
    bdemick Member
    Federal Way, WA
    I have a 2006 Tacoma Double Cab 4x4 Short Bed, automatic V6 with Tow Package and with two adults I tow a Keystone Passport 2650BH 26ft travel trailer. The trailer weighs 4960lbs unloaded and between 5600 & 5800 lbs loaded. I use an Equal-I-zer Brand 4 point weight distribution hitch with built in sway control and a Prodigy P2 brake controller. While this is quite a load for the Tacoma at no time does it feel unsafe, sway or bounce. I tow in 4th gear and at 60 mph I'm turning 2500 rpm. At inclines I drop into 3rd gear and turn 3000 rpm. My fuel mileage takes a big hit and I get between 10.5 and 11.75 mpg depending on inclines and road conditions. Not the ideal tow vehicle for a trailer this size, but it does an OK job. Just take your time and don't be in a hurry! The Tacoma is a beast!
    Attached Thumbnails [​IMG]
    Surprised how? More weight? Less weight? The empty trailer weight should be close to accurate because there are no options to add to this trailer. Everythings standard and, while not completely accurate, I do keep a close eye on what we put into it for camping. I only tow it with about 15 gallons of water in it and fill up when I arrive or hookup to water. Going to a scale might be a good idea, but I know the Tacoma, with two adults & one large cat, hauls this much load without too much stress. Accelerates nicely and brakes with ease. No sway or bounce. Again, not the ideal tow vehicle for a trailer this size & weight, but it really does tow it ok.
  7. Jun 28, 2012 at 5:25 PM
    #47
    sechsgang
    Yeah, you are probably okay with two adults.
    What I mean with surprise is the payload, mainly. Sticker said 1,200 lbs for my Taco, but I had under 1,100 lbs really available (after add-on's I did, and "stuff")
    The Tacoma (and most half tons) are payload limited, most of the time. With two people, it would depend on what else you put in the bed, but you are probably fine.
    With my Tacoma, and under 1,100 lbs of payload I was pretty much at / over the limit once I hooked up the trailer (600 lbs tongue weight) and got the 4 of us in the truck with no cargo, bikes, gear, firewood, etc. It was no fun, and I could feel that I was over.
  8. May 19, 2013 at 2:09 PM
    #48
    CAMPAIGN4LIBERTY
    CAMPAIGN4LIBERTY New Member
    CAMPAIGN FOR LIBERTY
    DEEP E TX
    12 TSS SR5 4X4 LB 2X-CAB V6 AT
    dog scratches.
    Ya'll are the most whimpy minded people. I have pulled 11,000# net until the frame broke on an 85' diesel. Now have a 2012 DC 4x4 LB V6 and pulling a 33' 3 axel Holiday
    Rambler with a weight distr hitch and two trailer sway controls. If you can not drive please do not attempt this.
  9. May 19, 2013 at 2:12 PM
    #49
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Good post on a year old thread
  10. May 19, 2013 at 2:16 PM
    #50
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    When you hit and kill someone, you will be living in a cardboard box when their families lawyers get done with you.. Your the reason auto ins. Rates are the way they are. GTFO.
  11. May 19, 2013 at 2:18 PM
    #51
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    Seems like the fucktards have been out full force all weekend...
  12. May 19, 2013 at 2:20 PM
    #52
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad
    Pure genius! :rolleyes:
  13. May 19, 2013 at 2:21 PM
    #53
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Rate suckers from Progressive. Use the snapshot. This was a dumb ass thread to post something else stupid in.
  14. May 22, 2013 at 4:59 PM
    #54
    bdemick
    bdemick Member
    Federal Way, WA
    Attached Thumbnails[​IMG]
  15. May 29, 2013 at 4:59 AM
    #55
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Disagree, it is the length you should be worried about..... Tacomas have, by their design, very short wheel bases.... Something that huge will lead to trailer sway, instablity, etc.... Weight is important too, but very few people who are new to RV's look at length factors.... In short, probably too much trailer. Next thing to look at is the all important weight factor.
  16. May 29, 2013 at 5:18 AM
    #56
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I wouldn't even attempt towing something like that with a Tacoma, if you are set on that trailer maybe hunt for an old suburban as a tow vehicle.
  17. Jun 6, 2013 at 8:27 PM
    #57
    03stepsidetaco
    03stepsidetaco Member
    David
    centralcoast CA
    03 stepside taco
    For my 03 4X4 excab V-6 my 19.5 wildwood is plenty. maybe I should have gone with a 20' dubble axle? wights not bad at all but sway from wind,passing big rigs, it does push a bit. better with air bags but I'll not be going over 21' MAX with a toy no matter what. I had and towed with an 83 chev one ton crewcab dully. so I know what it's like to use both kinds of vehs. I'd draw the line at 21' with a toy. thats for me not mean to be seen as telling anyone anything more than what I'd do for me.
  18. Apr 27, 2015 at 2:47 AM
    #58
    Ken k
    Ken k New Member
    Ken
    2015 Tacoma prerunner I-6 w/HD tow
    Well I see a lot of comments about weight and weight distribution. Let me just say that there are hitches widely used the distribute the weight evenly along all the tires. If the trailer is in your towing rang and capacity, there's a good possibility you could tow it just fine. Tongue weight is an issue, you may have to stiffen your rear suspension with air ride shocks but in many cases you can tow just fine. going up some of the steeper grades may be an issue because of the 4 liter v6 but that's a whole other discussion about power plant and hills, and gear ratio. Most tacomas can handle the mini lite class of travel trailers just fine. I have a 25 ft Forest River Rockwood Mini Lite. It weighs 4500lbs with a 515 lb tongue weight. I have a 2015 tacoma with the I6 tow package. I installed a Curt weigh distibution hitch with sway control. It pulls like a dream, sure I have to gear down for steeper grade and poke up the hills, but then again I don't have a $60,000 Dodge with an 8 liter power stroke diesel either. I do just fine, get educated, go to a reputable RV dealer ask about the weight dribution kits they sell and see what they say... some of the responses on here seem to be lacking that knowledge.
  19. Oct 16, 2016 at 4:11 PM
    #59
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    I tow a 27ft which has a dry wt of 4700lbs. I probably put up to a 1000 lbs of stuff in it.
    I put the tranny in 4th and set the cruise to 60 mph. It revs 2500 rpm. On smaller inclines it drops to 3rd a revs go up to 3500. No big deal. Not scary at all. I guess I should mention the brake controller and WD and sway control hitch. They are a must. I am very happy with the way my Tacoma tows.
