Can a tire of the same size at stock be taller?
Discussion in 'Off-Roading & Trails' started by ERdept, Feb 18, 2008.
  1. Feb 18, 2008 at 4:51 AM
    ERdept
    ERdept [OP] Well-Known Member
    I told a coworker that I was going to replace my stock BFG Rugged Trail's 265/70/16 with the same size BFG AT's on the Prerunner, and he said the replacements would make the truck taller because they were taller tires.
    I thought same size meant same size. Is he right?
  2. Feb 18, 2008 at 6:00 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Maybe. If so the difference is minimal. It is base on tread depth. If you check out http://tirerack.com, you can compare the two. It is probably no more than 1/4 inch difference.
  3. Feb 18, 2008 at 6:14 AM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Unfortunately, same size is not same size, but like 007 said, the difference shouldn't be a whole lot. The actual size varies from brand to brand and model to model. The websites of the tire maker will also have those measurements if the tire in question is not available at Tirerack.
  4. Feb 18, 2008 at 7:25 AM
    ERdept
    So the guy at work was hallucinating.
    He said the BFG AT of the same size of the stock Rugged Trails of 265/70/16 would raise the vehicle 1 inch!
    He must be a descendent of the philosopher Stupidicus.
  5. Feb 18, 2008 at 8:36 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i think that the biggest difference i've seen between the same size is like..... .2-.3 inches
