can a Toyota (or any) stay running in idle overnight?
Discussion in '1st Gen. Tacomas (1995-2004)' started by dhomsey, Feb 16, 2013.
Thread Status:
Not open for further replies.
  1. Feb 16, 2013 at 7:51 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    Thanks...:rolleyes:
  2. Feb 16, 2013 at 7:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    aren't is still wrong after your edit
  3. Feb 16, 2013 at 7:52 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Uh oh. :eek:
    Hey I don't know about wear and tear on the engine but I do know that you can die from exhaust.
  4. Feb 16, 2013 at 7:53 PM
    blake5995
    Blake
    Truckee, CA
    Thanks Mr. Spell Check
  5. Feb 16, 2013 at 7:53 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    thats the only way i go camping, screw sleeping in a cold tent.
    also one time my heat went out in the house and the truck is quite cozy when its 40 degrees in the house. 280k on the odometer
  6. Feb 16, 2013 at 7:54 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Your cat can read??????:eek:
    Mine is dumber than a box of nails....what breed is it?:cool:
  7. Feb 16, 2013 at 7:54 PM
    OZ-T
    Peter North
    British Columbia
    Don't want anyone to think you're stupid while you're calling people stupid .
    :thumbsup:
  8. Feb 16, 2013 at 7:54 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You're some kind of asshole aren't you?
  9. Feb 16, 2013 at 7:55 PM
    OZ-T
    Peter North
    British Columbia
    * Constable Spell Cheque
  10. Feb 16, 2013 at 7:57 PM
    blake5995
    Blake
    Truckee, CA
    No I am just wondering why you said what you did. It is all lies...
  11. Feb 16, 2013 at 7:57 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    *RCSP (Royal Canadian Spelling Police)
  12. Feb 16, 2013 at 7:57 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Hmmm... I'm gonna test this theory. Hopefully the Ultragauge monitors oil pressure :D
    If the truck truely does lose oil pressure the longer it idles, you could set an alarm on the ScanGauge or Ultragauge so it'll wake you up so you can rev it up for a few minutes.
  13. Feb 16, 2013 at 7:58 PM
    blake5995
    Blake
    Truckee, CA
    Haha I have never been to good at English...
  14. Feb 16, 2013 at 7:58 PM
    jandrews
    '09 FourDubDee TRD OR
    Rich is correct. It is NOT good for the truck as a whole.
    Is it going to cause a catastrophic failure? No. Will you even necessarily notice the difference? Probably not.
    He's correct however...idling is when ICE's are at their least efficient, and the excess uncombusted fuel has a deleterious effect on the cats, cylinder lube, spark plug electrodes, and byproduct buildup within the combustion chamber and engine oil.
    The only time I would expose the truck to this type of wear would be life-critical situations such as Btnewman's example of extremely cold weather where the vehicle might not restart if shut off.
    Edit to note: Oil pressure would not be an issue.
  15. Feb 16, 2013 at 7:59 PM
    #35
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    lol @ butthurt.
  16. Feb 16, 2013 at 8:00 PM
    #36
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Well if you want to idle that long, Be sure you have some spare exhaust valves, a new cat, and you might want a spare brain too after the CO poisoning.
  17. Feb 16, 2013 at 8:01 PM
    #37
    Rich91710
    Rich
    Los Angeles
    08 Base
    Oil pressure is going to depend on the vehicle/engine and it's state of repair.
    Some may hold 40psi at idle, others may not.
    My '94 dropped like a rock at idle. My motorcycle idles at about 9psi when the engine is hot.
    Ultragauge doesn't watch oil pressure... all we have is a switch.
    Do what you want to the engine, my main concern is exhaust fumes. It doesn't take much. I'd never sleep in the cabin of a running vehicle.
  18. Feb 16, 2013 at 8:02 PM
    #38
    blake5995
    Blake
    Truckee, CA
    The problem with this theory is the ECU monitors fuel distribution to the cylinders and wont send excess fuel.
  19. Feb 16, 2013 at 8:02 PM
    #39
    Runn0r
    Runn0r Well-Known Member
    NC
    07 Prerunn0r
    Lol...Gas generators/pumps etc... run way faster than idle with centrifugal oil-slingers in air-cooled stationary position for hours on end...in various conditions without fail, even with the increasingly lower than historical quality standards of companies like Briggs and Stratton as the powerplant. I am pretty sure....and I hope to God....Toyota engineering is at least that good. After all you do have a fan blowing on the radiator.. IMO the engine is as rested as it can be at idle. less RPM = less heat. But yeah I would watch out for co2 in stationary air. Other than that as others have said...maybe slightly increased oxidation of plugs and exhaust parts? but really how bad could it be.
  20. Feb 16, 2013 at 8:08 PM
    #40
    Pugga
    Massachusetts
    You can't compare a truck to a generator. Much, much, much different application...
Thread Status:
