can a Toyota (or any) stay running in idle overnight?
Discussion in '1st Gen. Tacomas (1995-2004)' started by dhomsey, Feb 16, 2013.
Thread Status:
Not open for further replies.
  1. Feb 17, 2013 at 5:51 PM
    #101
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No , I meant you
    Where's my avy
  2. Feb 17, 2013 at 5:52 PM
    #102
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    I'm not willing to tell other people how to live. Everyone must weigh the options and make their own choices.
    Once the 'safetycrats' take over, off-roading, skydiving, skiing, etc. become activities we must 'save each other' from. :rolleyes:
  3. Feb 17, 2013 at 5:52 PM
    #103
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Well apparently the monitors were not working properly. You may not die quickly but the brain cells go first.
  4. Feb 17, 2013 at 5:53 PM
    #104
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  5. Feb 17, 2013 at 5:54 PM
    #105
    Devout
    Seattle
    03 TRD 4X4
    None yet
    Got it. :D
    No singling out with derogate terms. ;)
  6. Feb 17, 2013 at 5:54 PM
    #106
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Roughly when did that become common? Not just for Toyota, in all applications?
  7. Feb 17, 2013 at 5:54 PM
    #107
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah....I'll check in a little while. Just got a fresh bottle of jager, and Im patiently waiting for the temp to reach an acceptible 24* before I drink it. Im thinkin the avitar is somewhere in the bottle.
  8. Feb 17, 2013 at 5:55 PM
    #108
    OZ-T
    Peter North
    British Columbia
    K
  9. Feb 17, 2013 at 5:55 PM
    #109
    Devout
    Seattle
    03 TRD 4X4
    None yet
    We test 100% every morning.
    Apparently, you have no experience with such equipment. :)
  10. Feb 17, 2013 at 5:56 PM
    #110
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Devout, nothing you have posted has proven anything. Yes, the introduction of cat convertors greatly reduces the amount of CO produced by a combustion engine but does not mean that it can no longer kill you. You attempted to say, or strongly implied, that a modern vehicle with properly functioning cats does not produce CO, period. That could not be further from the truth and plenty of people have died from the exhaust of modern vehicles. Comparing those deaths to being trapped in a confined space and dying from dehydration is extremely ignorant.
  11. Feb 17, 2013 at 5:56 PM
    #111
    OZ-T
    Peter North
    British Columbia
    It's a general observation that there have been a bunch of DB's join up lately , generally speaking
  12. Feb 17, 2013 at 5:56 PM
    #112
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Most all aluminum block engines use a steel sleave for the cylinders. Given the thin wall make up of the sleave, you cant bore it when rebuilding an engine. If the cylinder walls arent damaged, you might be able to hone it and re ring the pistons to regain compression, however......most all times Ive seen an engine loose compression due to an issue with the piston, the bore needed to be over bored to regain its use.
  13. Feb 17, 2013 at 5:57 PM
    #113
    ABA180
    East Bridgewater MA
    Could be a leak, but also it was stated that the tailpipe was blocked on the vehicle.
  14. Feb 17, 2013 at 5:58 PM
    #114
    Devout
    Seattle
    03 TRD 4X4
    None yet
    A German manufacturer started it in the 80's.
    Cheaper to manufacture, more durable and higher performance. Has zero to do with emissions.
  15. Feb 17, 2013 at 5:58 PM
    #115
    babytruck
    NorCal
    Maybe not but you are giving misinformation that could be dangerous. Again. The monitors were not working properly.
    From here on I've decided not to waste my time arguing with someone who is DEVOUT to their own beliefs regardless what the risk is to others.
    OP, please don't risk yourself. It can be very bad. If it doesn't kill you, it will damage your brain cells as proven above.
  16. Feb 17, 2013 at 5:58 PM
    #116
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yes I have. I've been in spaces that required a certified gas-free engineer clear before I entered them, I've worn multiple styles of gas pager/monitors and respiration equipment.
    And you are right...Lots of things can kill you, but executing bad ideas because of misinformation isn't good. It is still a fact that a modern FI engine can kill you...Might not be common or likely, but dismissing it as impossible is wrong.
  17. Feb 17, 2013 at 5:59 PM
    #117
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . . . Sub'd . . . to enrich my brain cells . . . :eek:
  18. Feb 17, 2013 at 6:00 PM
    #118
    babytruck
    NorCal
    lulz
  19. Feb 17, 2013 at 6:00 PM
    #119
    Devout
    Seattle
    03 TRD 4X4
    None yet
    Could have had no CAT (Year), Could have had no CAT (removed), could have had a faulty CAT (leaded gas or excess oil consumption).
    Too many variables to make a life rule around. :)
  20. Feb 17, 2013 at 6:01 PM
    #120
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    From the link I provided:
Thread Status:
