Can an after market muffler harm an engine?
Discussion in '4 Cylinder' started by tacoma02, Mar 28, 2010.
  1. Mar 28, 2010 at 7:57 PM
    tacoma02
    tacoma02 [OP] Well-Known Member
    2002 Toyota Tacoma 2.7L 4 Cylinder
    Thrush Welded Muffler Westin safari light bar
    I just went to an automotive store not to long ago to get an idea on a performance muffler for my 4 cylinder 2.7L and when i asked the guy there he told me that high flow mufflers will do alot more harm to a 4 cylinder engine over time as opposed to a v6 or v8. He said that the back pressure created from the stock muffler is needed for the best performance and altering the exhaust would be a bad idea. Well i went ahead and got a thrush welded muffler anyway and it sounds great and I love it, but it would be great to get another opinion if I should have anything to worry about.
  2. Mar 28, 2010 at 7:58 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yeah, that guy was wrong. A muffler will not hurt your truck.
  3. Mar 29, 2010 at 6:10 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I dont think it would harm it , but he is right about an engine needing some back pressure for best performance.
    From what i hear and see, the stock muffler is huge, no real gains on the 4cyl with an aftermarket can.
    The dyno tests ive seen here or other tacoma sites show little gain in hp when using a performance muffler and a C.A.I.
  4. Mar 29, 2010 at 6:15 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I dont think it will harm anything. It may not give the performance people think but if you did it for the sound like I did I think you will be fine.
  5. Apr 1, 2010 at 3:32 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Maybe with engines made back a few decades, a free-flow muffler might cause some exhaust valve wear over years of driving but not today's engines. You will be fine.
