Can Android Auto be setup to work wirelessly - 2020 TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Veccster, Jul 25, 2023.
  1. Jul 26, 2023 at 1:36 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    It was definitely the 4. Would not work with either of my Pixels (5 or 7), and the truck did not see anything but Carplay when plugged in.
    Have since upgraded to a Pioneer DMH-WC6600NEX so I have no use for an adapter and all the glitchiness from the stock HU even with wired AA is gone.
    doublethebass[QUOTED] likes this.
  2. Aug 1, 2023 at 9:51 AM
    Veccster
    Veccster [OP] bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    OP here...I purchased the Motorola MA1 and it's working as intended. I do get a slight issue at times with it not resuming music after a call ends. But has been starting up properly each time I get in the truck.
    I wish the clock on AA was bigger. It's tucked down in the bottom right corner and is pretty small to read at quick glance. Maybe someday I'll find a small digital clock to add to the dash board.
    Any tips on mounting this? Is the sticky that comes with it not strong or is the mounting location (under the dash) not going to hold any double sided pad?
    What have others with this device done to hide it???
    This is how I found mine 4 hours after sticking it inside the cubby...
    AIL4fc9d3pGljy3okKpZ9Aa6axkaGGu7jtZ8on7q_0f9fdf26bd7df06ed9c5a5e630446f3972db87a9.jpg
  3. Aug 1, 2023 at 10:21 AM
    apowers
    apowers '23 TRDPro6MT Solar Octane
    Yup, the sticky stuff is weak! But I have a 6MT so it stays out of the way for me as it is!
    Veccster[OP] likes this.
  4. Aug 1, 2023 at 2:13 PM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    I used velcro adhesive and stuck it to the underside of where the plug is. makes it easy to take it out if you need to
  5. Aug 2, 2023 at 8:14 AM
    02tacotoy
    02tacotoy Active Member
    Does the Motorola A1 work for 2017s? Thanks,
  6. Aug 2, 2023 at 8:20 AM
    Veccster
    Eric
    2020 Pro
    I don't have a 2017 but I think it would work on any vehicle that starts up Android Auto when you plug your phone into the dash USB.
  7. Aug 2, 2023 at 4:35 PM
    apowers
    I don't think Tacoma's had android auto or carplay till 2020 model year.
    batmanis243 likes this.
  8. Aug 4, 2023 at 9:05 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    You could pop it out of the dash, add one of these: https://www.amazon.com/gp/product/B072LZRB1D?ie=UTF8 , and then relocated it to your glove box. Thats what I did.
  9. Aug 4, 2023 at 1:25 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I have the Carsifi wireless Android auto adapter. I find it decent. I do have an audio dropout once in awhile and on rare occasions it will disconnect from the head unit. Otherwise it's good. It does take 30 to 45 seconds after the head unit is booted up to connect to my phone. There are settings in the app to have it auto start. Mine will nearly always start on the last music app I was using, plexamp and pick up where I stopped in the play list.
    Google maps works fine. I can even say hey Google and ask it to navigate somewhere or place a call. I however don't think to use all the voice commands it probably can do. The on screen Android auto is so simple and quick to use for me.
  10. Aug 4, 2023 at 7:30 PM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
  11. Sep 18, 2023 at 4:10 AM
    Bails
    Bails Well-Known Member
    Tampa, Florida
    2023 TRD Sport 2WD
  12. Sep 18, 2023 at 4:12 AM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    How did you connect to the USB? Did you plug in and run wire behind or connect somehow within the dash? Would like to not have us the actual USB that is in the dash.
  13. Sep 18, 2023 at 8:46 AM
    shaggy135
    I popped the USB port out of the dash. Drilled a hole in the glove box, installed it, and then connected it all inside/behind the dash. You'll have to pull the stereo out to reach it all though. Make sure to tape the connections too so they can't separate. Mines been running like that for over 4 years now with no issue.
    TRDRed likes this.
