Can anyone answer why no 4X4?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigrog74, Mar 17, 2009.
  1. Mar 17, 2009 at 2:18 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    You want extra weight to get more traction.
  2. Mar 17, 2009 at 2:19 PM
    Hardcorehehaw
    Hardcorehehaw 1 man wolf pack
    Evan
    09 Magnetic Gray PreRunner
    Debadged, 20" Liquid Metal Magmas, Yokohama Parada Spec x 285/50/20, Llumar clear bra, Fold-A-Cover G4, Weathertech liners, Wet Okole seat covers, JBS technologies keyless entry keypad.
    In loose sand with 2wd you can have more weight, but no thanks for me.
    Weight only helps with traction if it's over the wheels that are spinning under power.
  3. Mar 17, 2009 at 2:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Easy, everyone.....
    The drag created by the front diff, when off roading is negligable. The Prerunner and the 4x4 have the same chasis, suspensions and shocks. Truck for truck, I bet they would both go just as far in 2 wheel drive. Silverback is right, in that any resistance from the front drive wouldnt affect the performance off road. And the extra weight...Well, Im not so sure that would matter either. We are talking about 300# +/-...that could be the weight of one buddy and a cooler of food and drinks, and Im not sure I ev er had to throw someone out to get a little farther in one of my trucks.
  4. Mar 17, 2009 at 2:28 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    but youve probably tried!
  5. Mar 17, 2009 at 2:31 PM
    Hardcorehehaw
    Evan
    I've done it in an airboat, thats for sure.:p
  6. Mar 17, 2009 at 2:39 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    WHos Johnny Hopkins??
  7. Mar 17, 2009 at 2:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have never THROWN someone out, but I did have a buddy get scared and bail out on me...:D
  8. Mar 17, 2009 at 2:53 PM
    Hardcorehehaw
    Evan
  9. Mar 17, 2009 at 3:00 PM
    Hardcorehehaw
    Evan
    That would be putting weight over the tires that are spinning under power.:thumbsup:
  10. Mar 17, 2009 at 3:14 PM
    Hardcorehehaw
    Evan
    1-2mpg is 6-11 percent of fuel economy at 18mpg.
    The reason a 4wd truck has a 6-11% decrease in fuel economy is a direct result of the additional friction and weight.
    I'm not saying that a 4wd is going to get stuck everywhere in 2wd, I'm saying if you put the two trucks side by side the 2wd will go further, even if it's only an inch.
    If the 4wd gets stuck the 2wd will most likely be getting stuck too, but under certain conditions it will make it further.
    I've seen this in person.
  11. Mar 17, 2009 at 3:15 PM
    Hardcorehehaw
    Evan
    A 4wd in 2wd doesn't spin the front tires unless it's locked in 4wd. Common silverback, you should know this....:rolleyes:
    What good does additional weight do in the front if the front wheels aren't spinning?
  12. Mar 17, 2009 at 3:18 PM
    JimBeam
    JB
    2015 Tundra
    i'd be willing to test this "theory" out against someones prerunner
    i'll leave mine in 2wd and we'll see who go's further on the same trail
  13. Mar 17, 2009 at 3:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you have seen it in person, did the same guy drive both vehicles? Driver is the biggest factor in off roading....
  14. Mar 17, 2009 at 3:28 PM
    Hardcorehehaw
    Evan
    Both guys drove both trucks, the 4x2 went further, faster every time.
    This was in loose sand at a construction site.
    Two Chevy Silverados.
    You know what happened later that day? The 2wd guy got stuck show boating and had to get snatched out.
  15. Mar 17, 2009 at 3:29 PM
    #35
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I'll take you on. You leave it in 2wd, and Im gonna use a HELICOPTER!!!! :D
  16. Mar 17, 2009 at 3:29 PM
    #36
    Hardcorehehaw
    Evan
    Way to be mature.
  17. Mar 17, 2009 at 3:30 PM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  18. Mar 17, 2009 at 3:32 PM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :D
  19. Mar 17, 2009 at 3:35 PM
    #39
    Hardcorehehaw
    Evan
    I don't off road anymore... you know nothing about me, dude. You're getting way to hostile and defensive for this and I have nothing to prove to you.
  20. Mar 17, 2009 at 3:39 PM
    #40
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    You guys are wrong, a STOCK Taco 2WD Prerunner OR will go further than a STOCK Taco 4WD OR in 2WD.
    You have to put the 4WD in 4lo to engage the locker :)
