Can Anyone Balance Tiress Correctly or Even Do Roadforce On All Terrain Tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaGus, Sep 9, 2010.
  1. Sep 9, 2010 at 6:35 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    how did they balance them on the truck?
  2. Sep 9, 2010 at 6:52 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I really have no idea....but they do it..that and turn the rotors while on the truck. Like I said its the only shop that does it within atleast 150 miles from me.
  3. Sep 9, 2010 at 11:37 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Is that really possible?
  4. Sep 10, 2010 at 8:38 AM
    Toyota4x46921
    Michael
    Warner Robins, GA
  5. Sep 10, 2010 at 8:42 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    IT may have to do with your wheels. The shops may not be using the correct adapter when balancing your tires which would give them a false reading when doing it.
  6. Sep 10, 2010 at 8:47 AM
    scocar
    scocar hypotenoper
    The Haweka adapter is only for the aluminum Toyota wheels on first gens and early Tundras. It has no use for aftermarket wheels. I have an info sheet on it at home, so I can 't post it right now.
    Anyway, as other s have said, it still comes down to three variables: the skill of the person balancing the wheel, using a correctly calibrated dynamic (or road force) balancing machine, and the tire quality. Good luck, man. This can be so frustrating.
  7. Sep 10, 2010 at 10:34 AM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    it's finally done! I got them road forced today at a Glotfelty Tire Center and they did a great job. No more vibes and the truck rides so much better. They even did the chalk line test on my tires to get the correct psi. They were super professional and the guy even took me into the shop to show me how the road force machine was working and how he would do it all which was cool. Plus it only costed 60 bucks for the road force. Super cheap for what i have seen it being on here.
    i recommend Glotfelty Tire Center to anyone in the morgantown area
  8. Sep 10, 2010 at 10:57 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    don't assume anthing. my toyota dealer had no idea what a haweka adapter was. they had to order one after i bitched about them not balancing my tires worth a shit. ..i took it to them 3 times. 3 times they balanced it without using the finger adapter.
    interestingly enough, the vibration issue was a result of piss poor tires. 2 of them were out of round. never will i purchase anything with the word "NITTO" on it again.
  9. Sep 10, 2010 at 12:19 PM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    I beg to differ about the Maxxis. I bought Maxxis Big Horns 32x11.5 R15 from Big 10 Tires and they drive perfect.
  10. Sep 10, 2010 at 1:16 PM
    scocar
    scocar hypotenoper
  11. Sep 10, 2010 at 1:57 PM
    shampoop
    southwest WA
    maybe you got lucky but nearly every maxxis and pegasus i've ever balanced (hundreds) were at least moderately out of round. it's actually a very consistent trait, the cheaper the truck tire, the more likely they were to be out of round when balancing.
  12. Sep 10, 2010 at 8:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    :yay:That is awesome. Great outcome.
  13. Sep 10, 2010 at 8:30 PM
    bowhuntingaddict
    bowhuntingaddict Well-Known Member
    I have the same problem with vibes, got new 285/75/16 BFG ATs and helo wheels and my truck shakes, got them road force balanced at discount tire and it didnt help at all. What should i do?
  14. Sep 10, 2010 at 9:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Does it 'shake' at all speeds? Where do you feel the vibs, steering wheel? Or seat/floorboards?
  15. Sep 10, 2010 at 9:22 PM
    #35
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    +1 Maxxis=cheng shin=garbage. At least in the motorcycle world.
  16. Sep 11, 2010 at 6:30 PM
    #36
    bowhuntingaddict
    its most noticable in the steering wheel
  17. Sep 11, 2010 at 9:03 PM
    #37
    Digiratus
    Roaming the PNW
    The RedHead
    Generally, a vib in the seats and floor boards indicates an issue with the rear wheel/tire combo. Since your feeling the vib in the steering wheel you might try moving the rear wheels to the front to see what changes. You'll know if the vib changes that it is something with those two front wheels you moved to the back. If nothing changes, if you still have the identical vib, it is probably not caused by a wheel/tire.
  18. Oct 26, 2012 at 11:10 PM
    #38
    Jareds Toyota
    Jareds Toyota Well-Known Member
    Jared
    Washington
    2008 AC TRD Sport
    How did they "true" your tires, I have duratracs too and I believe they are out of round.
  19. Oct 27, 2012 at 7:28 AM
    #39
    Toyota4x46921
    Michael
    Warner Robins, GA
    They put them on a machine and shave them down until they are round...i have had to do it twice since buying them....lose a little tread but rides like a camry.
  20. Oct 27, 2012 at 7:53 AM
    #40
    02sr5trd
    02sr5trd Well-Known Member
    Donnie
    Ohio
    02 SR5 TRD OFF ROAD 4x4
    Deckplate Mod, AFE Pro Dry filter, Xcelerator 14'' muffler, AAL, 5100's @2.5, Kenwood DD HU, Alpine speakers.
    I have worked in tire shops, Ant there are times if a tire wont balance out or calls for excessive amounts of weight that you need to bust the bead and spin the tire on the rim and try again. when i had my duratrac's mounted the tech put multiple weights inside and out and they were not even the right ones for my wheels! i took it to another Goodyear store to have it fixed and the manager said WTF was that tech thinking. They took care of me there, and i have not had a problem with vibrations.
