Can anyone help with shifter bushing replacement?
Discussion in 'Arizona' started by Sido, Apr 2, 2014.
  1. Apr 2, 2014 at 9:30 PM
    Sido
    Sido [OP] Well-Known Member
    Anchorage
    None
    Trying to replace the shifter bushings- I have the white O-ring thing and the cap that goes on the end of the shifter (I think/ hope they fit).
    I can't get the shift lever cap to budge. I know I'm supposed to press down and turn counter clockwise, but I can't get it to move more than 1mm. I can't get it to go down any further and it doesn't turn in any direction.
    I wanted to see if anyone nearby has replaced these, and if I could meet up for some help.
  2. Apr 2, 2014 at 11:05 PM
    TheRedHorseman
    TheRedHorseman Well-Known Member
    I've done them, use some big needle nose pliers to push down on the collar. You sometimes have to put a bit of grunt into it.
