can anyone make some stickers for me??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MROBERTS, Jun 23, 2010.
  1. Jun 23, 2010 at 3:07 PM
    MROBERTS
    MROBERTS [OP] Active Member
    Stevenson AL
    06 PreRunner SR5
    10000k hids, horn relcation, and more
    I am wanting a few custom stickers for my truck nut i cant find anyone to make them for me:eek:
  2. Jun 23, 2010 at 3:07 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    Mr. Sockmonkey? Heard of him?
  3. Jun 23, 2010 at 3:12 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    SoCal
    07 PreRunner SR5 V6 Black
    ^^ sock does great work
  4. Jun 23, 2010 at 3:49 PM
    75thrangertaco
    75thrangertaco Sua Sponte! RLTW
    charles
    casper wyoming
    procomp 6 inch co lift ,305/55/20 xtreme a/t tires,4.88 gears ,,grill shell painted white billet inserts.Trd cat back ,
    I. Thought sock wasnt makine any. New. Designs
  5. Jun 23, 2010 at 4:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What type of stickers are you looking to get made?
    Stickers aren't just something anyone can whip up with ease. Depending on what you want and what you start off with - will determine how much time and headaches it takes (and what it'll cost you). If you don't provide the exact type of file format - then the images/files have to be worked - and that can be a ROYAL PAIN IN THE ASS.
    **my husband has a vinyl cutter
  6. Jun 23, 2010 at 4:03 PM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    That must be whey sockmonkey never got back to me. The pictures I sent needed to be reworked for sure.
  7. Jun 23, 2010 at 4:23 PM
    JoeyTacoma
    JoeyTacoma Well-Known Member
    Eagle, Colorado
    2017 TRD Off-Road Pro Cement
    285/75 R16 BF Goodrich All Terrain KO2
    I have a vinyl cutter and might be able to help. What kinda stickers are you looking for. Vinyl stickers are one color only.
  8. Jun 23, 2010 at 4:35 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    you can do multiple colors by layering but the decal will be thicker.
    Post the image of the decal, if I have a chance I can digitize it so it'll be simpler for someone to cut or print in vector format.
  9. Jun 23, 2010 at 6:33 PM
    JoeyTacoma
    Eagle, Colorado
    epa4wd is correct you can layer the vinyl for multiple colors. I did not want to open that can of worms. I was offering to help out if you are looking for sticker that are just one color. (All green, all red, all silver, etc. etc. if you want to layer a red sticker on top of green sticker for instance you can do that. I am not going to pre-layer them, it is just to time consuming for me unless you are willing to pay. Here are some pics the trd on the roof rack is one color just silver. The bedside trd is black and silver (pre-layered) The Trd on the rack is easy and cheap. the trd on the bedside not so easy and not so cheap [​IMG][​IMG] look hard and you can see the silver shadow under the black (pre-layered)
  10. Jun 23, 2010 at 6:41 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    Very Very Nice!
  11. Jun 23, 2010 at 8:12 PM
    Janster
    Jandy
    Lancaster, PA
    You are absolutely right....
    However - Sockmonkey's stickers are not the same type or process. His stickers are not your typical vinyl cut-outs. I don't know what the process is called, but I think it involves actually 'printing' the graphic.
    This is a sticker from Sockmonkey.... My husband & I actually designed the graphic and sent it to Sock so he could produce the sticker. THis type of sticker would be a royal nightmare to make in the standard vinyl format as you're referring to. Not only that, but the overlapping & thin lines wouldn't withstand the elements and would probably peel up over time.
    http://www.lieblweb.com/cpg/albums/ToyotaTacoma/2007Tacoma/normal_Driversticker.jpg
    Maybe Sock can explain his process for us?
  12. Jun 23, 2010 at 8:21 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    Yeah I think he uses some kind of thermal plotter/cutter (hell of expensive). That particular decal you posted I would usually cut the white part first (solid) then place the red part on top of it. Vinyl over vinyl will stick very very strongly. Attached is a similar kind of decal I made (bottom layer black top layer yellow)
  13. Jun 23, 2010 at 8:27 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    This is the one on my rear window, 3 layers
    Attached is one I did for my brother, exact replica of original FORD decal (original decal was removed when truck was restored) has been on the truck for a few years now.
  14. Jun 23, 2010 at 10:53 PM
    Janster
    Jandy
    Lancaster, PA
    Yes, my husband would do the same thing.
    However, with that paticular logo I posted - He did not want to tackle it for a variety of reasons. And mostly - because he does not have the proper vinyl at home and did not want to spend $$ on buying new rolls just to make 2 small stickers for me. It was cheaper to have someone else do it.
  15. Jun 23, 2010 at 11:10 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    I understand, very nice deign btw looks good on the scoop. I got to say this one awesome forum, lots of talent. I mean we got members doing custom emblems, shift knobs, decals, bumpers, skid plates etc etc... definitely not like any other forum I've been part of. :headbang:
  16. Jun 24, 2010 at 4:36 AM
    sockmonkey
    sockmonkey Well-Known Member
    Greg
    Benbrook, SW Fort Worth
    2007 White Dbl Cab Pre-Runner
    Volant Ram Air intake,URD MAF calibrator, Mr Marv 10" sub box, Alpine HU, Alpine Amp, fog light mod, scan gauge II, RAAMmat front and rear doors, Wet Okole seat covers, blacked out dash. Retro stripes. blacked out front bumper. 265/70/16 Goodyear Wrangler Adventures. NST Lite Pulleys
    unfortunately, i cannot see any of the images.
    but post #9, here, i give a description of print vs. cut.
    you can always PM me with questions.
    Greg
