can anyone tell me what happened here
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremyk61, Nov 3, 2013.
  1. Nov 3, 2013 at 8:31 PM
    jeremyk61
    jeremyk61 [OP] Well-Known Member
    Saw a puddle of oil under passenger side of 2005 truck. Looked and this is what I saw. How in the world did the axle pull away from the housing or did something else happen?
  2. Nov 3, 2013 at 8:40 PM
    drupp
    drupp Well-Known Member
    Pennsylvania
    '06 Access Cab TRD Off-Road
    If I'm seeing that right, it looks like the seal is leaking, as opposed to the axle popping out.
  3. Nov 3, 2013 at 8:42 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    X2 the axel looks good just snafu seal
    vvvvvv Good advice right there too
  4. Nov 3, 2013 at 8:42 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The axle will have a little play in and out. You probably will need to replace the seal and since you'll be in there get the ECGS bushing too.
  5. Nov 3, 2013 at 8:47 PM
    jeremyk61
    Thanks guys. Already did the bushing and put this axle and a new seal in at the same time back in june. Why the gap between the dust cover and housing? It use to be flush against the housing and I thought the snap ring would keep it flush. This is passengers side btw.
  6. Nov 3, 2013 at 8:52 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Doesn't look right to me.
  7. Nov 3, 2013 at 8:55 PM
    jeremyk61
    Here's the drivers side to compare position of dust cover
  8. Nov 3, 2013 at 8:56 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    c-clip on the end of the axle break?
  9. Nov 3, 2013 at 8:59 PM
    jeremyk61
    That's what I'm wondering but have no idea how that would happen or if it would allow the axle to shift that much.. Think it caused any damage?
  10. Nov 3, 2013 at 9:01 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    If the clip was floating around in there it definitely could. I would definitely pull the axle and check.
    Also how's your alignment? I wonder if the LCA was "adjusted" all the way out would it give the axle this added play?
  11. Nov 3, 2013 at 9:06 PM
    jeremyk61
    Alignment seems fine. Whatever hapoened just happened today. I used 4 wheel drive briefly today to climb a steep hill is all out hunting.
  12. Nov 4, 2013 at 6:35 AM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    well, if you can pull the axle out of the housing as it sits, the clip ring fell off or broke.
  13. Nov 4, 2013 at 6:44 AM
    gearcruncher
    Canadain bumper technician
    OEM replacement axles or aftermarket ?
  14. Nov 4, 2013 at 7:02 AM
    jeremyk61
    OEM axles. No issues with it for several months then all of a sudden this happened.
    Anyone ever have a c clip fail before? Did it cause any other damage?
  15. Nov 4, 2013 at 7:29 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    C clip is made out of very soft metal, 9 out of 10 times simply gets chewed by gears and ends up on the bottom of differential as mangled pieces of metal. I would not worry much about it. Fix axle so it sits better, change diff fluid while you at it.
  16. Nov 4, 2013 at 7:31 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    How would you "fix the axle so it sits better"?
  17. Nov 4, 2013 at 9:17 AM
    jeremyk61
    got it tore apart and everything looks fine but something had to have pulled that axle out.the LCA is one possible cause but not sure why all of a sudden it would be after 100k miles.
    Anymore ideas? obviously I am concerned about it happening again.
  18. Nov 4, 2013 at 1:46 PM
    jeremyk61
    Starting to wonder if it ever got seated properly.....not sure I used four wheel drive much since I installed the axle in june.
  19. Nov 4, 2013 at 1:48 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    i had an axle popping out just like yours, it is because of the c clip.
    go get a new c-clip, put that on and put it in again and you should be fine. thats what i had to do to get it to stay in there.
    no other damage was caused because the ring stayed on the axle, it was just really weak and didnt hold the shaft into the diff.
  20. Nov 4, 2013 at 2:17 PM
    jeremyk61
    Thanks for the info. I inspected the c clip and it looked fine, but the thought did cross my mind to replace it. However I opted not to and really wish I did now. I will keep an eye on it and if it happens again definitely replace it.
