Can anyone tell me which factory button works like a normal toggle switch?
Discussion in 'Technical Chat' started by BRYLONATOR, Feb 17, 2012.
  1. Feb 17, 2012 at 12:10 AM
    BRYLONATOR
    BRYLONATOR [OP] Building 06 Suburban K2500 with LBZ D-max and ZF6!
    Denver, Colorado
    Chillin in a 120!
    I want to do the abs mod but I am looking for a factory switch to do the job. I don't want just a simple toggle. Problem is that the switches that I would like to use would either be A-trac or trac control but it is my understanding that they would not interupt the signal rather they are designed to simply send a signal to the ecu and then the ecu sends a signal back to the switch to shut it off. My truck is an 07' and never came with those features. Am I safe to say that the only factory switch that can be used like a toggle would be a fog switch?
  2. Feb 17, 2012 at 11:40 AM
    BRYLONATOR
    Denver, Colorado
    Chillin in a 120!
    thank you very much!
  3. Feb 17, 2012 at 12:37 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the ATRAC button should work as well. it is only on when the buttom is pressed. i want to get one and make it my yellow wire mod switch. :D
  4. Feb 17, 2012 at 12:44 PM
    The_Hodge
    SC
    gimme yours...you dont want it :D
  5. Feb 17, 2012 at 12:47 PM
    The_Hodge
    SC
    guess i need to go to cali and take someone else's. they wouldnt know how to offroad then. :rolleyes:
    i really do need to do this though. for a temp solution, i used a simple switch from my daystar lights that wasnt used.
  6. Feb 17, 2012 at 12:55 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    FTFY
  7. Feb 17, 2012 at 1:02 PM
    The_Hodge
    SC
    same diff
  8. Feb 17, 2012 at 1:04 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i would get the front end of your truck fixed before you go looking for a toggle switch mod
  9. Feb 17, 2012 at 1:31 PM
    The_Hodge
    SC
    :drevil:
  10. Feb 17, 2012 at 1:40 PM
    The_Hodge
    SC
    best i can do ATT...
  11. Feb 17, 2012 at 1:54 PM
    The_Hodge
    SC
    this plus my ATRAC most interesting man in the world pics sum it up.
  12. Feb 17, 2012 at 2:36 PM
    BRYLONATOR
    Denver, Colorado
    Chillin in a 120!
    problem with this is I learned that it too gets shut off by a signal from the ecu....is this true or does it function like a typlical toggle as well? I just want to interupt the signal and connect it back when I want so I can shut off abs for days not a moment!
  13. Feb 17, 2012 at 2:46 PM
    The_Hodge
    SC
    i would think that since the ECU shuts off the ATRAC, regardless of the shitch position, the switch would function like normal. it's not like the switch is physically being toggled.
  14. Feb 17, 2012 at 3:02 PM
    BRYLONATOR
    Denver, Colorado
    Chillin in a 120!
    Yeah and that is my problem.....it needs to function simply like an on and off switch and have complete control. Otherwise it is nothing more than a signal sender as opposed to something that actually physically opens and closes the circuit itself.
