Can anyone tell me....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Mar 5, 2009.
  1. Mar 5, 2009 at 8:56 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    What is an "indexed drill bit"? I need to find a #11 indexed drill bit and have no idea what that is. I think a #11 may be close if not the same as a 3/16" bit? Thanks! Phil
  2. Mar 5, 2009 at 9:02 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    A #11 is .191" in diameter.
    What is your application? I have never heard of an "indexed" drill bit.
  3. Mar 5, 2009 at 9:58 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    It was referenced in the instructions to install the Redline Hood Struts. This bit would be used to drill the hole a rivet goes in.
  4. Mar 5, 2009 at 10:03 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The only thing I can think of as far as an "indexed" drill bit is the bit have three ground flat spots on the shank. This keeps it from spinning in the chuck. The flat spots are 120 degrees apart. I will see if I can fin a pic some where.
    Oh, you should be fine with the 3/16" bit. There is only .0035" difference.
  5. Mar 5, 2009 at 10:09 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    An Index for drill bits is the case holding them according to size. An "indexed" drill bit is one that matches the specific size. A #11 drill bit referes to the specific size of the bit.
    If you purchase a #11 bit you will be fine.
  6. Mar 5, 2009 at 10:11 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Here is one
    This step drill has them too.
    The flat spots are generally not put on wire size (Numbered) bits because of the bits size. It compromises the integrity of the shank.
    You should be fine with the 3/16". You are only drilling rivet holes. Hope this helps.
  7. Mar 5, 2009 at 10:12 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    This is from the exact tools list from the Redline Installation Manual:
    • 3/16", indexed #11 & 5/32" drill bits
  8. Mar 5, 2009 at 10:15 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Get all three from you local hardware or Lowes/Home Depot. They are cheap at that size. Best to cover all bases.
  9. Mar 5, 2009 at 10:22 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Dudes, Dudesses and Dudendums.....many thanks! It's off to the hardware store I go (I need very little reason to spend an hour walking around Lowes). :)
  10. Mar 5, 2009 at 10:22 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Great info JDCPA. I have never heard.
  11. Mar 5, 2009 at 10:26 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    There is nothing in the UNIVERSE that cannot be answered on TW!!! I vote TW in, Congress out!!!
