Can anyone walk me through a CRUX CTY-02 Backup camera install?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by little bear, Apr 22, 2019.
  1. Apr 22, 2019 at 11:59 AM
    little bear
    little bear [OP] Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    I have removed the old handle and wires, installed the new handle/camera and connected the connector while using the factory cable runs through the tailgate and into the bottom of the truck bed. I have 25ft of an rca cable to run and a several feet of red and black cable to ground and somehow get into the reverse 12volt power supply of the backup lights. Anyone done this yet? Any pictures---
  2. Nov 27, 2019 at 5:24 AM
    Tanginator
    Tanginator Member
    Dallas TX
    2006 Tacoma 4x4 SR5
    Did you get this to work? I tried, didn’t work.
  3. Nov 27, 2019 at 1:11 PM
    little bear
    Barry Hobson
    Canadian, Texas
    Mine is working fine now but only after I took it to my local audio installer and he did his thing it works like it’s supposed to
  4. May 20, 2020 at 5:24 AM
    IdriveaTRD
    IdriveaTRD New Member
    I was able to install this camera.
    So a few tricks and points. I may not have done it the "right" way, but it works.
    1. The instructions really suck. While it can be a pretty straightforward install, better instructions would help. There is a decent youtube video about a differnt camera but it does show the places to run the cable so it's good to search it out. https://www.youtube.com/watch?v=hBk7dfWCgR0&t=330s
    2. I pulled 12V power from the driver side reverse light. Actually I just used wire taps and pulled both the + and - from there. I had to look up the wiring diagram.
    3. I pulled the reverse power for the sradio from the wiring harness in the footwell. In theory, I could have pulled the power from the reverse light also, but whatever, this worked.
    4. I ran the cable mostly along the frame and poked it up through a grommet that is under the outside rail of the driver seat. I should probably seal that back up with something.
