Can anyone walk me through installing a backup camera?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tucker771, May 19, 2015.
  1. May 19, 2015 at 7:29 PM
    Tucker771
    Tucker771 [OP] Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    I'm hoping yall can help me. I have a backup camera but have no idea how to install the damned thing. Any help would be much appreciated!
  2. May 19, 2015 at 7:36 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    4 meters of duct tape and a Polaroid and your good to go!
    ... or do a site search.
    Just sayin'
  3. May 20, 2015 at 11:31 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    ask yourself questions and then post them here. right now we have absolutely no frickin' idea what you purchased or how you want to run it :D
  4. May 20, 2015 at 11:57 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    What are you using for a monitor? Is the camera an aftermarket flush mount or license plate frame mount? A few questions need to be answered.
  5. May 20, 2015 at 12:01 PM
    SMHdavid
    SMHdavid Well-Known Member
    David
    California
    Sport
  6. May 20, 2015 at 12:35 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
  7. May 20, 2015 at 2:25 PM
    SMHdavid
    David
    California
    Sport
    This is true.
    I see this now lol
    I tried...
  8. May 20, 2015 at 3:16 PM
    smuook
    smuook Daily Driver "Plus"
    Smuook
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
  9. May 20, 2015 at 11:33 PM
    SR5Tac0
    SR5Tac0 Well-Known Member
    Los Angeles
    98 SR5 V6 4x4
    I installed one last year and wired it to my reverse lights. Whenever I put my truck in reverse the camera and monitor both turn on. Some people wire their camera to a toggle so they can have it on at all times. Can you post what camera and monitor you have? I can say that after installing my setup, parking in LA has been a hundred times easier.
  10. May 21, 2015 at 6:53 AM
    Tucker771
    Tucker
    Raleigh, NC
    Thanks for all the help yall! I have it wired to my in dash pioneer system and I just tapped into the reverse light like someone else had said. A surprisingly easy process. I can do a write up if anyone is interested. The hardest part was running the wires through the cab (still not too difficult). It's always daunting cutting wires for me I got lucky and cut the right one! The only problem I'm having now is when the truck goes into reverse I have to manually turn the camera view on from my in dash, it's not automatic. Anyone with suggestions for fixing that??
  11. May 21, 2015 at 7:23 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    your HU manual should have instructions to set it when turned on. if not then your stuck with manual :(
  12. May 21, 2015 at 9:41 AM
    Tucker771
    Tucker
    Raleigh, NC
    Well...now it's stuck on the camera mode and will not let me access any menus...so I look at a black screen unless I'm in reverse and the camera is on. Slightly confused
  13. May 21, 2015 at 7:17 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    disconnect the power and let it reset (either battery or if you have it pulled out disconnect the harness)
  14. May 22, 2015 at 8:37 AM
    Tucker771
    Tucker
    Raleigh, NC
    Turns out there's a wire coming from the radio I had to splice in. All is working great now! Thanks for all the help!
  15. May 22, 2015 at 8:58 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    start a DIY thread on it and help others who might be planning or trying to do the same thing. just be very detailed with pictures and explanations.
    share and pay back a little for the help you always find at this great site
  16. May 22, 2015 at 11:56 AM
    Tucker771
    Tucker
    Raleigh, NC
    Will do!
