Can balancing detect an out of round rim?
Discussion in 'Wheels & Tires' started by greyeyezz, Nov 7, 2023.
  1. Nov 7, 2023 at 12:16 PM
    greyeyezz
    greyeyezz [OP] Well-Known Member
    New rims, Discount tire mounted and balanced. Steering wheel shimy and vibration felt in seat. Discount tire rebalanced the next day, says everything looks good. Problem continues. There were 0 issues before these new rims. Have another appt. friday. I have to have a bad rim. How do I find out which one?
    obligatory pic of rig
    [​IMG]IMG_20231106_142553970
    HondaGM likes this.
  2. Nov 7, 2023 at 12:22 PM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    Could be that their machine is out of calibration, could be that they aren't doing something right, could be a high spot on a tire, etc...was this road force or standard spin balancing? as long as the machine is running true, and the wheel is clean, a dial indicator would show any errors in concentricity
  3. Nov 7, 2023 at 12:45 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    have you double checked air pressure, I usually find they have aired up over 40psi after tire service
    Travlr and Bill0351 like this.
  4. Nov 7, 2023 at 12:48 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    tires are same as previous or new ones?
  5. Nov 7, 2023 at 1:20 PM
    greyeyezz
    Tires are same, pressure consistent, road force. I will repeat, I had zero issues with my old rims and this tire combo.
  6. Nov 7, 2023 at 1:22 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Are those actual TRD wheels or copies?
  7. Nov 7, 2023 at 1:41 PM
    greyeyezz
  8. Nov 7, 2023 at 2:04 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @greyeyezz Discount Tire uses a Road Force balancer and would detect an out of round or bent wheel. I did not see where they posted the hub diameter of the wheel you purchased, so if the wheel is not hub centric at 106.10mm then you must use an E/T lug to center the wheel properly. Something you might want to bring up when you go in for your Friday appointment.
    saf023 likes this.
  9. Nov 7, 2023 at 2:53 PM
    greyeyezz
    So you recommend E/T lugs over hub centric rings?
    I passed your info on BTW thanks.
  10. Nov 8, 2023 at 9:16 AM
    Discount Tire
    Arizona, USA
    @greyeyezz larger hub bore sizes typically don't have hub rings readily available. If you have them, then by all means use them. The E/T lugs would be used in addition to the rings.:thumbsup:
    Wulf likes this.
  11. Nov 8, 2023 at 10:24 AM
    greyeyezz
    Could you post a link to the lugs you would recommend?
    My lug seats are flat I'm 90% sure. That taper on the edge is probably 1/32 so any conical type lug probably won't work.
    [​IMG]IMG_20231108_124045239
    [​IMG]lug seats
  12. Nov 8, 2023 at 10:25 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    The wheel appears to be a mag seat wheel. Should not require an ET lug, correct me if I’m wrong.
  13. Nov 8, 2023 at 10:27 AM
    gotoman1969
    Did you use mag seat lugs? Correct you can not use an acorn seat lug.
  14. Nov 8, 2023 at 10:32 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  15. Nov 8, 2023 at 10:35 AM
    Discount Tire
    Arizona, USA
    @greyeyezz I do apologize, if your wheels require the factory mag lug, then the E/T lug nut option would not work for those wheels. I mistook your wheels to be aftermarket like the DX4 Beast.
  16. Nov 8, 2023 at 10:44 AM
    Yoda_Mike
    Yoda_Mike YotaWerx Authorized Tuner
    Michael
    South Glens Falls, NY
    2019 Tacoma TRD Sport
    YotaWerx Blackhawk 2.0 tuned. Typer Auto tail light guards. Rough Country tri-fold tonneau cover. Start-X remote starter. Injen CAI. MBPR Armor Plus high clearance exhaust.
    In my experience, out of round rims are often detectible with your eyes when the wheel is on the balancer. However, assuming all is well with their equipment, it's also possible it's a tire (or more than one) causing the issue. This can be harder to detect visibly. The best way to locate an issue of this nature is a road-force balancer. These balancers have a pressurized roller that simulates road surface contact while measure the "roundness" of the wheel and tire. It can detect things like shifted belts in the tire or manufacturing defects that cause an out of round condition.
    Other considerations are the hub size and lug nuts (Toyota trucks use both hub centric and lug centric wheels from the factory) as well as the method of balancing. Make sure the shop is not static balancing your wheels. This would be indicated by the lack of weights applied just inside the face of the wheel. Static balancing places weights only on the inside edge of the wheel, while dynamic balancing positions weights on both the inside and outside edges of the wheel.
    ridefreak likes this.
  17. Nov 8, 2023 at 10:46 AM
    greyeyezz
    I used my factory lugs.
    [​IMG]IMG_20231108_122627429 by
    I'm back to square one.
  18. Nov 8, 2023 at 10:49 AM
    greyeyezz
    The issue is the wheels not being hub centric.
  19. Nov 8, 2023 at 10:59 AM
    gotoman1969
    Possibly, it appears they have a 130.4 hub bore in the description on the website.Although since the wheels are a mag seat wheel this may not be as big a factor @Discount Tire may chime in on this.
  20. Nov 8, 2023 at 12:36 PM
    Discount Tire
    Arizona, USA
    Vibration issues result when the assembly is not centered on the vehicles hub. Hub centric wheels or hub centering rings are required to make sure the wheel is as close to factory as possible. @gotoman1969 the 130.4mm that you see in the description is the backspace of 5.13inches. I do not see the wheels center bore in the description. 106.1 would be ideal.
    gotoman1969 likes this.
