Can driveshaft U-joints go 200k + ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DGXR, Mar 25, 2016.
  1. Mar 25, 2016 at 12:17 PM
    DGXR
    DGXR [OP] Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    My 2006 2wd 4-cylinder access cab is driven 90% on the street, the other 10% is graded gravel roads. All moderate/gentle driving, I almost never "push" this thing hard. It hauls dirt bikes and camping gear about 15 times per year, and rarely tows anything. It's got 120k and everything looks, feels and sounds fine. Mechanically I think it is near perfect. I've researched but haven't seen any service interval or service life for the driveshaft u-joints. If they keep working smoothly and quietly, I think they will go 200k... and potentially more, but I would definitely replace them at 200k.
    I don't understand why they didn't install u-joints with grease nipples. A lame way to save 8 cents, methinks.
    Anyway, just wondering if those who know these drivetrains think that 200k on factory u-joints, under light service, would be pushing my luck. Thanks
  2. Mar 25, 2016 at 12:19 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    time to replace them I betcha. Its a cheap 150-200 piece of mind
  3. Mar 25, 2016 at 12:25 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    greaseable ones can go a million miles
    non-greaseable ones go until they develop slop felt when truck is frame lifted and you manually twist on the prop
  4. Mar 25, 2016 at 1:59 PM
    DGXR
    Friend
    Sacramento, CA
    How can you tell if the slop is in the differential gear or in the u-joints?
  5. Mar 25, 2016 at 2:02 PM
    2000TRDTaco
    2000TRDTaco Well-Known Member
    Corey
    Angier, NC
    00 Prerunner
    My 2000 prerunner with 202k miles has the original greasable u joints still
  6. Mar 25, 2016 at 2:09 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm 500mi away from 200k and the ujoints actually feel pretty good. The diff has slop though.
  7. Mar 25, 2016 at 2:21 PM
    MKMotorsport
    MKMotorsport Well-Known Member
    AZ
    '15 DCSB TRD/OR
    All-Pro skid'd, UGMx1.3, 7pin delete via rock
    Depending on use obviously, and care to a lesser extent... I'd say more than likely. You know how many old school RWD cars went to the junkyard with 100k+, never ever having being greased or cared for?
    Now if you dunk yours in water or mud regularly all bets are off.
  8. Mar 25, 2016 at 3:51 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I had 175,000 on mine when I traded it in and had no issues. To tell if the slop is the joint or the diff..... Block your wheels, put your trans in neutral, crawl under and rotate your drive shaft by hand, watch the joints. If there is slop, you'll see it,
  9. Mar 25, 2016 at 3:54 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    @ 200,000 miles all original joints
  10. Mar 26, 2016 at 9:14 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  11. Mar 26, 2016 at 2:05 PM
    Speedytech7
