Can Entune GPS be recalibrated?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by locster, May 13, 2015.
  1. May 13, 2015 at 3:04 PM
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    The Entune GPS position for my truck is off by at least 300 ft, and with the signal transmission lag time, that can extend up to 500 ft in some cases. Driving in mountain areas or at night, I would miss a road or a turn.
    I tried to play with the calibration arrows on screen, but it's not changing anything. Can it be reprogrammed or is there a way to recalibrate it?
  2. May 13, 2015 at 5:30 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    I'm not sure there is any calibration you can do to a GPS receiver. Being that far off is really odd. Was this just once or is it all the time? These built-in GPS units are not very helpful sometimes, where a Garmin will tell you how many satellites it can acquire at once. If you can only see 2 or 3 due to geography, that might cause this. But otherwise, it is a pure time-based system that should work as you would expect. Perhaps it actually has an internal defect, that is about the only other thing I could think of.
