Can fog lights be set to come on with highbeams?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mfdchief, Mar 3, 2014.
  1. Mar 3, 2014 at 7:24 AM
    mfdchief
    mfdchief [OP] Well-Known Member
    Louis
    Rhode Island
    I have seen the always on mod but wondering if anyone has found a way to wire them to their high beams. This way I can run those and my grill bar with the regular high beam switch?
  2. Mar 3, 2014 at 7:41 AM
    fla taco
    fla taco Well-Known Member
    Central Florida
    05 Dblcab TRD OR
    There is a mod posted on wiring the fog lights to work with parking lights, regular headlights and high beams. I did it to me 05 and have had no problems. I think it was posted in technical chat. I'll see if I can find the link.....
    where you at in RI? I used to live up there.....can't say that I miss it...especially with the winter you guys are having.:cool:
    Here's the link:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/4838-cheap-free-mods.html#post45430
  3. Mar 3, 2014 at 7:46 AM
    BlueBomber
    BlueBomber Well-Known Member
    Luke
    Upstate, NY
    09 Taco SR5 4x4
    Magnaflow 14"
  4. Mar 3, 2014 at 7:57 AM
    mfdchief
    Louis
    Rhode Island
    I have read those but I am looking to have them come on/off with my high beam switch.
  5. Mar 3, 2014 at 8:50 AM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    Last time I drove in heavy fog, the highbeams seemed to make visibility a lot worse.
  6. Mar 3, 2014 at 9:04 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yes, you can make them only come on when your high beams are on. Read the anytime mod and just modify it to suit your needs. The anytime mod uses the parking light power wire as the 'trigger' for the relay. Your parking lights are always on when your lights are on so it's essentially an anytime fog light mod. Swap out the parking light wire for your high beam wire and there you have it, you're all set. A test light will tell you which wire is hot when your high beams are on, just tap that and run it to the fog light relay.
    All that being said, it's completely and utterly pointless to have your fog lights ONLY come on when you have your high beams on. You typically don't want your high beams on in fog or heavy precipitation and you don't want your fog lights on when your high beams are on. Fog lights are short throw and light the road up directly in front of the vehicle, high beams are for distance. By lighting up the road just in front of you, your eyes focus on that and it makes your distance vision worse. You're better off cutting off the fogs when you want distance.
  7. Mar 3, 2014 at 9:08 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    And that's why you don't drive with the high beams on in fog.
    OP I know there is a "anytime fog" thread but I'm not sure that is what you are looking for. I don't have mine wired that way but my LED bar is wired into the high beam circuit so when I flip my high beams on the LED bar comes on rendering the Fogs useless. Since mine is a combo flood / spot it floods the outside and spots down the road. I can just turn the bar off so the high beams come on by themselves also.
    Hope you find what you are looking for. I understand the rational.
    *EDIT* Never mind, Pugga answered it.
  8. Mar 3, 2014 at 10:21 AM
    mfdchief
    Louis
    Rhode Island
    I understand the purpose of "fog" lights but I replaced my bulbs with brighter LEDs and have my Aux LED floods wired to fogs as well. Want to be able to activate them with high beam LEDs when on dark road, the beach, etc... During heavy snow, fog, etc... I only run the lows.
  9. Mar 3, 2014 at 10:57 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    So why not just do any of the "anytime fog light mods" so you have full control over when the foglights are on.
    Check the link in my sig.
  10. Mar 3, 2014 at 11:01 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    This or add 1 more switch with wiring...IMO that would be a more logical thing to do...
  11. Mar 3, 2014 at 11:49 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    this is a fact lol better to make them switchable
